Old 10-23-2015, 02:01 PM   #1
custommx3
custommx3's Avatar
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS
Homelink Harness
I purchased a used homelink unit and am looking for a harness to power it. It has some sort of blade style connector on it. Anyone know where I can get one relatively cheap? Anyone parting out a car?
Gen5diy has one, but I'd rather not spend 40 bucks on something that simple.
http://www.gen5diy.com/Home-Link-Har...ry=true&page=2
custommx3 is offline   Reply With Quote
Old 10-23-2015, 06:12 PM   #2
Jylee
Drives: 2012 2LT
I suggest to use same electical clips, it should only be a hot and ground wire to power the unit.
Jack
Jylee is offline   Reply With Quote
Old 10-23-2015, 06:34 PM   #3
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
The OEM homelink is wired to constant 12 volts, I rewired mine and tapped it into the sunroof power. That way it only has power when the ignition is on. Did this on my Suburban, Tahoe and Silverado as well. That way if someone happens to break into one of my vehicles when I'm not home, the can't open the garage door.
Just something to think about.
Low Saturn is offline   Reply With Quote
Old 10-25-2015, 02:36 PM   #4
custommx3
custommx3's Avatar
Do we know the pinouts? There are 3 connections.
Old 10-25-2015, 04:40 PM   #5
stantmann
stantmann's Avatar
Drives: 2012 Camaro Convertible LT
Ironic, I put mine in today. I just swapped out the overhead console with the replacement console, it came with the entire wiring harness. Worked perfectly, and programed it for my garage. If you bought the entire console, it only takes a few minutes to swap it out.
2012 1LT
Standard: Convertible, Fog lights, Steering wheel controls, USB/Ipod/Auxillary ports, backup cam on mirror.
Mods:
20" OEM Chrome Wheels, HUD, HomeLink, SS leather seats, tow package with Ohio State hitch cover, CCFL Angel Eyes, SS Frontend, sequential signal lights, auxillary guages, Knight Rider Oracle scanner lights.
stantmann is offline   Reply With Quote
Old 10-25-2015, 04:57 PM   #6
stantmann
stantmann's Avatar
Check this thread out Darth Martel made me one that I never used. I just tried to hunt it down, damn, nowhere to be found. It's basically a harness that goes over the 3 connectors in the pic above. The other side is open, just + and - (red and black). You can do this yourself though, just read the thread above. Not sure if Darth is still making them, last time I checked he sold his 5th gen, but he is still active on the site. http://www.camaro5.com/forums/member.php?u=10046
2012 1LT
Mods:
Old 10-25-2015, 04:59 PM   #7
Low Saturn
Low Saturn's Avatar
If its typical GM its:
Pin A: 12 volts
Pin B: Illumination
Pin C: Ground
Pin B would be unused.
Old 10-26-2015, 10:57 AM   #8
custommx3
custommx3's Avatar
Thank you guys SO much! This has helped a lot! I sent him a message to see if I could get a harness from him. if Not I at least have the pinouts to try and make my own.
Old 11-08-2015, 12:48 PM   #9
baddmans
Banned
Drives: 2015 Camaro 1LT
I have the 2 wire harness with the plug I got from Darth Martel. In fact I have the whole overhead console black with GDO buttons and the 2 wire harness with plug, to splice into positive and negative wires. No sunroof buttons in the overhead console.
baddmans is offline   Reply With Quote
Old 11-09-2015, 08:01 PM   #10
custommx3
custommx3's Avatar
Stantmann sold me a spare one he had, Thanks man!
I painted the one I had that was pulled from a salvage car that was a bit faded. I haven't spliced into the wires yet, but I did test out the harness and homelink module. Work flawlessly.
Now I have to figure out what's hot and what's ground in the '14 mirror.
Old 12-15-2018, 09:40 PM   #11
bjsmusic
Drives: 2011 Camero RS infernal Orange ,
Smile Home link
The wire harness is available from Gen5DIY
The power is on the left, ground on right, nothing goes in the middle, harness goes to fuse block, nice set up, worth the price. The overhead console with wires is the way to go, but hard to find,because most salvage yards cut the wires:
bjsmusic is offline   Reply With Quote
