Old 08-13-2018, 04:06 PM   #1
king II zl1
Drives: 2013 zl1 camaro
muffler Delete ZL1
Hi guys, was looking to do a muffler delete on my 2013 zl1 but am afraid if i ever wanted to weld on the Original NPP exhaust mufflers the butterfly flaps wouldn't work like they are supposed to, (i would get different tips so the mufflers would be one whole piece). Anyone try this or would have any info let me know! thanks.
king II zl1 is offline   Reply With Quote
Old 08-13-2018, 05:49 PM   #2
GONMAD510
Drives: 2013 ZL1 M6
Better off just pulling the fuse F8 in the trunk so the bypass stays open all the time. That way you can put the fuse back in and they will work normally.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 08-13-2018, 05:58 PM   #3
king II zl1
I did pull the fuse, just want it a bit louder
Old 08-15-2018, 09:45 AM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Do you have the stock H pipe or an X pipe? Stock cats? Headers? It would be easy to remove the rear cats and install a regular X pipe in place of the H for more volume. Dunno if you have to tune the Z at that point though.
DSX_Camaro is offline   Reply With Quote
Old 08-15-2018, 09:48 AM   #5
GONMAD510
Drives: 2013 ZL1 M6
I am running a set of Noweeds cutout diverters. If you want loud that will do it. When you want quiet you can just hit the button and close them. I am running them with no cats and a set of long tube headers. I don't think it gets any louder.
691.38 RWHP
630.35 RWTQ
Old 08-15-2018, 12:35 PM   #6
king II zl1
I cant touch the cats or tune anything because it will void my warranty, waiting until warranty expires to do LT headers, tune, and different pulleys. But for now I just want the car as loud as i can make it without voiding any warranty. The car is 100% bone stock from the factory. Was just wondering if anyone had done a muffler delete on a 5th gen zl1 to see how it sounded and if the butterfly flaps still work if i were to weld the mufflers back on.
Old 08-15-2018, 03:29 PM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
If you've pulled the fuse, you've basically got straight pipes already. I don't think you can get any louder until you do headers, and then it will be loud af!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
RobZL1 is offline   Reply With Quote
Old 08-28-2018, 06:44 AM   #8
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
You have a 2013...bumper to bumper was 3 years and Powertrain was 5 years..
Did you purchase an extended warranty?
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 08-31-2018, 03:58 PM   #9
king II zl1
Yes i did purchase an extended warranty, but for the 2012-2013 years the supercharger was extended under warranty to 10 years or 120k miles if im not mistaken (due to a faulty bearing within the supercharger). I was just looking to see if a muffler delete would make it any louder or not really haha thats all
