10-05-2011, 08:52 AM | #1 |
Drives: 2010 RS / 2017 SS Join Date: Sep 2011
Quick stupid question
Hey guys I know this is not a dodge forum, but my moms dodge grand caravan just overheated and I'm a car noob and don't know how or where to put water in it. Can u guys please help me thank you!!
10-05-2011, 08:53 AM | #2 |
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro Join Date: Jul 2010
Radiator overfill bottle.........................
10-05-2011, 08:54 AM | #3 |
Huh?
10-05-2011, 08:55 AM | #4 |
Ohh never mind thanx a lot man!!!!
10-05-2011, 08:57 AM | #5 |
Caspers2SSRS
Under the hood, screw on cap, squarish in shape..........marked.............."Do not Open While Hot"
10-05-2011, 09:01 AM | #6 |
Thanx very much!!
10-05-2011, 09:04 AM | #7 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
Find the source of the leak while you're at it. You've lost coolant somewhere and unless you fix it, you're just wasting your money literally down the drain.
10-05-2011, 09:07 AM | #8 |
Caspers2SSRS
10-05-2011, 09:08 AM | #9 |
you may want to check if the thermostat is still good and is not sticking close.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
10-05-2011, 09:13 AM | #10 | |
Bowtie 'til I Die!
To OP: You can google/youtube the radiator, follow the hoses or lines and check all the seals, also depending on the model year check the water pump (google/youtube) to be sure there's no leak there. I had a problem of overheating on my 04 Monte Carlo and I had a leak at the water pump, the thermostat needed to be replaced, believe it was stuck closed. All told I repaired the car myself by buying a used water pump from a salvage shop for 30 bucks that was warrantied by the shop, thermostat was 7 or 8 bucks from advanced autoparts, the haynes manual showing me how to get 'er done was 15. Anything I wasn't clear on I looked up on youtube since the impala and a potiac had the same motor. Good luck |
08-31-2014, 08:29 PM | #11 |
Drives: '10 RJT,'95&'14 Vette Join Date: Feb 2009
Check to make sure there's no leaks, wiki or others.
"As ye sow, so shall ye reap" - Me
Mine at sunset |
Similar Threads | ||||
Hellow new to the forums, and quick question | Ahaftman | 5th Gen Camaro SS LS LT General Discussions | 17 | 09-02-2011 04:15 PM |
Quick Question abt ARH with American Thunder Cat Back | BlackMambaSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 07-03-2011 05:07 PM |
quick question | BiG_TiMe | Cosmetics and Lighting Modification Discussions | 3 | 04-28-2011 09:00 PM |
quick question | spruce26 | 4th Generation Camaros | 7 | 02-14-2010 01:10 AM |
Quick Question About upgraded wheels | LSX-80MM | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 11-02-2009 03:07 PM |
