03-17-2022, 04:59 AM | #1 |
Drives: 2010ss Join Date: Oct 2018
Tuned and can’t brake stand now
In short had the car tuned (A6) and now that the season is rolling around and was looking to get to the track this weekend I mounted up the drag radials and went to do some testing in a local industrial area prior to this weekend. This was my first attempt to do a brake stand burnout. However with my foot on the brake and one on the gas no spin happened. I can floor it and car will only get to 1200 and tires on not spinning , yes TC is off. What could the tuner have messed up? Once you take foot off th brake there is a pause then the car goes
03-17-2022, 04:28 PM | #2 |
Thanks , I assumed it was something like that. Boggles my mind why that would be set that way from the tuner? Prior to the tune I had no issues. Honestly I think he just uploaded a file he had and Nvr dynoed it. To many odd things going on. Example: in park or N you can only rev to 3k.
03-17-2022, 07:18 PM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
The low revs in p or n is normal from the factory.
03-18-2022, 06:24 AM | #4 |
03-18-2022, 07:33 AM | #5 |
A lot of tuners will start with an existing file that they have already done to save time and especially if your tune wasn't stock. It can be time consuming to find all of the differences. I wouldn't really consider tuning to be a one and done process.
03-18-2022, 02:58 PM | #6 | |
Either way I have 3 “ reputable shops” all within same distance from me. CSP, RPM and Jannety. Going to dig deep and see who will do the job correct |
03-18-2022, 03:07 PM | #7 |
Yes he should be wiling to make needed changes for no additional charge. Some the things he should have asked about as part of the tuning process.
03-18-2022, 06:36 PM | #8 |
How about do it right the first time lol he knows how I use the car. Weekly raced at loc track in a bracket point series, I do about 3 or so big money races a year. Car came in with a drag pack, let’s turn on brake pedal torque management, tune the trans like garbage. Yea that’ll be good for him lol when I asked him if he set shift points on the dyno or if he at least did a 2-3 and 3-4 shift. I got some bs and knew then i was in trouble.
Thread Tools | |
