#Camaro6
AWE Tuning
Old 04-11-2018, 08:31 PM   #1
CPM
Drives: Black 2018 SS 1LE
Skip Shift Eliminator
Anybody else find it practically impossible to get their skip shift eliminator installed? I can't even get my hand up there to pull the factory plug. Any words of wisdom would be appreciated.
CPM is offline   Reply With Quote
Old 04-11-2018, 08:42 PM   #2
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Know any kids?
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 04-11-2018, 08:58 PM   #3
CPM
Yeah, but there’s not a jack stand in the world i trust that much.
Old 04-11-2018, 09:07 PM   #4
lugs
lugs's Avatar
Drives: 2016 camaro 1ss 6sp
Long screwdriver
lugs is offline   Reply With Quote
Old 04-11-2018, 09:09 PM   #5
Weege
Weege's Avatar
Drives: 2017 2SS convertible M6, NPP, MRC
Space is tight on Gen6 for installing the skip shift eliminator, especially since you have to use a small screwdriver to release a clip. I easily guilted my dealer to put my '17 on a lift, after they installed a front license plate bracket when they promised they wouldn't. Even with it fully lifted it took a little effort. But if all else fails, try to get it done with next oil change assuming car will be ramped or lifted. Good luck.
Did you hear about the restaurant on the moon?
Great food
No atmosphere.
Weege is offline   Reply With Quote
Old 04-11-2018, 09:21 PM   #6
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Check out this thread http://www.camaro6.com/forums/showthread.php?t=490112
May give you some help and ideas.
thescreensavers is offline   Reply With Quote
Old 04-11-2018, 09:34 PM   #7
donaldp
Drives: 2017 Red Hot ZL1 M6
I've done it on my ZL1 and on my neighbors 1SS1LE. It's doable but not easy. My hands are not small either. The one positive is that the connector that exists that you input the skip shift eliminator into is very easy to discconnect and to reconnect once you reach it.
donaldp is offline   Reply With Quote
Old 04-11-2018, 10:19 PM   #8
CPM
This looks promising. Thanks!
Old 04-11-2018, 10:37 PM   #9
Juiced1
Drives: 2012 2SS CAMARO 45th
Save some time and get it tuned. If you plan on doing any modding you'll need a tune sooner or later. You can tune that waste of time skip shift eliminator right out.
Juiced1 is offline   Reply With Quote
Old 04-12-2018, 06:40 AM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Mine was super easy. Just handed the dealer tech the SSE at my first oil change at 500 miles and said, "Here, install this for me." My '13 ZL1 was just as easy.
Old 04-12-2018, 06:48 AM   #11
ssmike
BL1ZZRD
ssmike's Avatar
I just did mine and it is a PITA! I watched the how to video on line and it looked pretty easy but in reality there’s just no room up there for your hand. I used a short flat blade screwdriver to unlatch the clip and the rest was a piece of cake!
Old 04-12-2018, 07:14 AM   #12
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
If it were to be tuned out would the message still be displayed?
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 04-12-2018, 09:18 AM   #13
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
Nope. Shouldn't be. But I'm sure GM would also figure out a way to screw you out of your warranty at that point. Depends on if you want to possibly void your warranty over a skip shift, or just install that one part. Although... They could probably figure out how to screw you over for that as well if they really wanted to be assholes.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 04-12-2018, 09:37 AM   #14
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
Turn it a little bit more (RPM's) and it eliminates the skip shift. I bet I've had it pop up 3 times in a year. Not an issue for my driving style.
51FIFFT is offline   Reply With Quote
