07-13-2015, 09:08 PM | #1 |
Drives: '13 1SS/RS IOM white stripes Join Date: Oct 2013
Will putting a taller sidewalled tire on the stock wheels
hurt the performance of my SS? ...and if not then what tire size?
07-13-2015, 10:20 PM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I wouldn't go taller on the sidewall than what it comes with stock, it's already a 40 series in the back and a 45 series up front.
If anything i'd use a smaller sidewall tire. What are you trying to accomplish? Less fender gap? If that's the case I would go with some 1" lowering springs to get the look you want.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
07-13-2015, 10:42 PM | #3 |
actually better ride comfort quality.
should i just go for a better brand than stock Pirellis.the roads over here are terrible. |
07-13-2015, 11:03 PM | #4 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
Try some Nitto Invos. Soft sidewall and quiet ride. Not great for handling, i.e.; AutoX or road course.
07-13-2015, 11:08 PM | #5 |
Drives: 2015 Red Hot SS/RS M6 Join Date: Sep 2012
The fronts on our 20" wheels are 245/45 (245mm wide, the height is 45% of that width or 110mm off the rim... there's 25.5mm to an inch, so that tire sits 4.3" off the rim)
I think it would be hard to find a performance tire in a 60 or 65 series. Sounds like a truck tire. But I get where you're coming from. You can get a set of BC Racing coil overs for the cost of a nice set of tires... you might want to try that.
07-13-2015, 11:30 PM | #6 | |
Drives: 2012 Inferno Orange 1SS/RS Join Date: Apr 2012
My Pirelli's barely lasted 18K before they were shot. They grip well but being so soft coupled with our crappy roads and they get ate up quickly. Especially if you do some spirited driving. While the BFG's are also a summer only tire, they are a little bit tougher than the P-Zero's. |
07-14-2015, 07:45 AM | #7 |
Try the Continental DW tires or DWS if you need an all season, the DW's ride quite well, my brother has them on his car, 275/40R20s all around. Also, the DW's grip quite well also, likely better than P-Zeros.
2010 2SS
07-14-2015, 10:30 AM | #8 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Taller sidewalls will create less handling responsive handling. If you get the diameters off front and rear it can also cause traction control/ABS issues.
I also like the Continentals The DWS would have a slightly better ride versus the DW. |
