03-25-2022, 11:12 PM | #1 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Catch can bracket
Have had a Mighty Mouse catch can since I bought the car. Never really liked how I had it mounted. Not a lot of info where to mount in these cars either. I had a piece of 1x1 angle aluminum that I drilled holes and grinded out to mount on the sump tank. I have been getting into CAD. Had this laser cut and bent for a sleeker, cleaner bracket. Going to paint or powder coat at a later time. But thought it turned out ok!
03-27-2022, 11:47 AM | #2 |
Drives: 2015 Z28 Join Date: Dec 2014
Nice. A little thin around the holes for my taste...but nice.
I have lived in the CAD and Fabrication world for 42 years now... Did you use an online source source for the Laser and Forming? I am taking my skill set to the next level. Bought a Faro Arm/Laser Scanner last week and this week I hope to boil down the best software solution for me??? Should be able to make anything with this. The old Romer Arm
"Resale value is my beneficiaries problem...unless they can bury my in my Z...problem solved."
03-27-2022, 01:46 PM | #3 |
It don’t come easy.
I agree on the holes having not much on edge distance. Although, the cap bolts look like there capturing those areas well.
03-27-2022, 06:23 PM | #4 | ||
Yes, I used SendCutSend to cut and bend it for me. They are pretty good priced and customer service is super helpful and responsive. The only thing I don’t like is that when I don’t know my exact measurements, I have to spend a little on prototyping with them too. For example, the first bracket I had them make, I made the sump holes about .20” more apart and it didn’t work obviously. So I had to revise and wait for them to do it again. If you have any tips on getting more precise measurements the first time, I’m all ears, as I am still new at it. Your machine looks awesome! Seems like you have made a career out of CAD. I got into it more from things like this, just making stuff nobody else does. Hobby stuff lol |
03-27-2022, 08:56 PM | #5 | ||
There is a different kind of CAD that may help you: CARDBOARD AIDED DESIGN Seriously draw you part out full size on heavy paper or cardboard and cut it out and see if it fits. Simple and easy. Quote:
MY brother and I own a Precision Sheet Metal Shop employing +/- 130 people today. We Turret Punch, Laser, Bend, Weld, Machine and some assembly. Not only is it a Career it is my hobby too. I design everything before building. Just starting to get into 3D printing too.
03-28-2022, 12:19 PM | #6 | |
Sounds like a great business. Also sounds like a lot of fun to work in too. Places like that always have work to be done too. Probably hardly slows down |
03-28-2022, 07:50 PM | #7 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Can you take pics of how the dry sump tank mounts into the car?
Orange Krush II
03-29-2022, 11:19 AM | #8 |
Heres the bracket that goes to top of radiator. And I believe it mounts to a crossmember underneath. Hope this helps
03-29-2022, 09:15 PM | #9 |
Yes it does thank you!!!
Orange Krush II
Thread Tools | |
