#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 04-07-2021, 09:32 PM   #1
Josedlc98
Drives: 6th gen camaro ss
Ff sensor pin
What other pin can you use for the ecu connector side for the ff sensor other than pin 38 ?
Josedlc98 is offline   Reply With Quote
Old 04-08-2021, 08:27 PM   #2
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Why ?, use 38 and be done with it.
lt4camaro is offline   Reply With Quote
Old 04-09-2021, 12:43 PM   #3
SilverSurfer18
SilverSurfer18's Avatar
Drives: 2021 1SS Camaro
I see you have a 2021. Have you installed flex fuel on yours yet?
2021 Wild Cherry 1SS, LT2 Intake, Rotofab, Borla S-Type, Texas Speed longtubes, SMG flex fuel sensor, GPI Tuning, Bronze 1LE replicas
SilverSurfer18 is offline   Reply With Quote
Old 04-09-2021, 02:43 PM   #4
lt4camaro
lt4camaro's Avatar
Yes, but I am not tuned for it yet...not turned on yet. I installed the sensor kit a month ago and waiting to get into the dyno shop to set up the tune for E85.
Old 04-26-2021, 03:01 PM   #5
Josedlc98
Long story short of my friends that installed it broke the little black tab that holds the pin
Old 04-26-2021, 04:58 PM   #6
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
You can use RTV to hold the pin in the connector. Or you can replace the wiring harness. Option 'C' would be to obtain the connector from a wrecked car and wire it in.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 04-26-2021, 05:49 PM   #7
lt4camaro
lt4camaro's Avatar
As long as the wire can be pushed into the hole and the clip stops it from being pulled back out, the blue lower base will hold everything in place and you push it all together and clip it.
Old 04-26-2021, 06:20 PM   #8
lt4camaro
lt4camaro's Avatar
Thats A good thought for me also.... thanks for that.
