06-01-2011, 04:32 PM | #1 |
Tyranny is Closing In
Drives: 2010 Camaro SS Join Date: Apr 2011
Help with Axles
So, I received a set of DSS Level 5 Axles and installed them in my brother's G5 Camaro this afternoon. We're all done except for the wheels, but guess what, the wheels won't bolt on because the axle bolt protrudes too far from the hub.
Has anyone else run into this with DSS axles? Huge PIA, my brother and I are supposed to hit the track this weekend Last edited by StreetStrip; 06-01-2011 at 06:54 PM. |
06-01-2011, 05:50 PM | #2 |
Sure its seated all the way? Factory Wheels?
Easy fix it just have the end of the axle shortened by however much is necessary at a machine shop. Should only cost a few bucks. Alternatively, you could do the same thing with a grinder if you have a die to chase the threads, but that might cause an issue with the heat-treat. |
06-01-2011, 06:14 PM | #3 |
PM Frank at DSS he can help you and will help you more than any one else.
06-01-2011, 06:19 PM | #4 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
06-01-2011, 06:54 PM | #5 |
Frank is a good dude, he said he could fix me up, but we went ahead and trimmed them so we could get the project done. It only took 4 - $8 Sawsall blades to cut that stuff, good grief!
Thanks for the responses guys. |
Similar Threads | ||||
Best Deal on DSS Camaro 2010 - 2011 Axles & Powder Coated | Paschal Performance | Transmission / Driveline | 2 | 07-15-2011 10:31 PM |
Our first DSS 9 Inch Conversion and Detailed review. | 55Designs | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 04-15-2011 09:24 AM |
Gforce Engineerings 4340 and 300m axles for the 5th Gen Camaro | GFORCE1320 | Transmission / Driveline | 12 | 12-04-2010 08:53 PM |
Best Deal on DSS Camaro 2010 - 2011 Axles | Paschal Performance | Transmission / Driveline | 8 | 09-18-2010 11:23 PM |
Hot Deal For DSS 2010 Camaro Axles | Paschal Performance | Transmission / Driveline | 3 | 03-04-2010 08:36 PM |
