09-21-2018, 05:35 PM | #1 |
using 2010-13ss borla axle back on 14-15 ss
Can anyone tell me the problems I will run into? It looks like (from the sales photos) the muffler to tips pipe might be at a different angle on the 13 ss from the 15 ss.
09-21-2018, 07:34 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
I would say that you are probably right since the whole rear changed in 14. I assume that the angles are probably slightly different. Couldn't tell you how much, but calling Borla on it might be the best answer for you.
09-21-2018, 08:19 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
I would imagine if Borla has two different part numbers for the years then its different some how.
09-21-2018, 09:15 PM | #4 |
Already purchased it, anyone kmow for sure? Thanks for the replies guys.
09-21-2018, 09:25 PM | #5 | |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
https://www.tdotperformance.ca/borla...EaArMQEALw_wcB Here is a S type for a 2014 or 15...different numbers..plus you need to let us know if its an Atak or Stype you have. https://www.borla.com/products/camar...rt__11849.html |
09-22-2018, 07:01 AM | #6 |
It is an atak. Not sure of the part numbers, it is a used setup from another member. I will be driving 3 hrs to pick it up. I will lay it out under the car to see what it looks like and update this thread once I attempt to put it on.
09-22-2018, 07:51 AM | #7 |
My guess would be that the exhaust tips may not be in the right position so you might have to re-work them.
10-05-2018, 06:05 PM | #8 |
The hangers lines up and the tips work fine. They are angled out a little bit but noone would ever think it didnt look right. The tips arent flush with the bumper cover but the uniformity between the two make it work and seem like a look you are going for. Cant speak about the rest of the Kit but the mufflers worked out fine.
