07-07-2015, 02:05 PM | #1 |
Drives: 2014 1LE - AGM Join Date: Dec 2014
Lashway TSP 235/239 Cam Install
Just got my 1LE back from Lashway Motorsports and I couldn't be happier.
They installed the TSP 235/239 - 112 LSA cam and dyno-tuned it to 486 hp/ 427 tq. I already had on all of the other supporting bolt-on mods (TSP 1-7/8 headers, VMax TB, CAI, Air Scoop and NPP) but the car was un-tuned with those for a couple of months. Car drives awesome - pulls hard all the way to 6.5K and slow speed surge is almost a non-factor thanks to Josh's tune. The wicked rough idle is just money! Thanks again to Erik and Josh @ LM for the great work and quick turnaround. You guys are true professionals! Dyno posted... Last edited by 2K141LE; 07-07-2015 at 02:06 PM. Reason: adding dyno image |
07-07-2015, 02:14 PM | #2 |
Drives: 2018 ZL1 A10 Join Date: Feb 2012
Those are great numbers!
07-07-2015, 03:29 PM | #3 |
Drives: 2013 2SS/RS convertable Join Date: Aug 2014
Great products, great tuner, great numbers.
2013 2SS/RS Vert
Mods list to long to fit in sig now lol Check build thread http://www.camaro5.com/forums/showthread.php?t=377507 |
07-07-2015, 08:15 PM | #4 |
Thanks guys; first cammed V8 for me so just loving it.
07-08-2015, 03:53 AM | #5 |
Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
Hmmm. I wonder what it is about this cam that absolutely kills torque? I mean, my 1LE made 423rwtq on a MUSTANG dyno with just bolt ons and a tune. Several thousand dollars later and you only gained 3lb/ft???
My build plan, up to now, has had this specific cam in mind, but with PRC 255 heads and 12:1 compression. The thought of surpassing 500 rwhp is enticing, but not at the expense of torque. I want to make at least 450lb/ft, and I'd sacrifice a little hp to get it(I'd still want to be teasing the 500rwhp mark, though ). Hopefully, it will just be a matter of a different LSA. Otherwise, I'll look into a custom grind.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. Last edited by Bodywerks; 07-08-2015 at 04:12 AM. |
07-08-2015, 09:42 PM | #6 |
Drives: 2013 Camaro SS2/RS 1LE Rally Yellow Join Date: Aug 2013
Great numbers. Glad it turned out well for you. Erik and Josh @ LM do great work, wouldn't let anyone else touch my car
2013 Rally Yellow SS 1LE.
527 RWHP 452 RWTQ Custom tuned by Lashway Motorsports PRC 255 heads, Fast 102 intake manifold, Nicky Williams TB, 25% Under Pulley Texas Speed cam 235/239, SW Long Tube Headers Roto-Fab Cold Air Intake, NPP Exhaust, BMR 1:25 springs |
07-09-2015, 01:49 PM | #7 | |
Drives: 2013 camaro 1ss 1le Join Date: Jul 2015
07-10-2015, 02:32 AM | #8 |
Thanks for that info. Any compression bump milled into the heads? I'm either going 255 or 260 heads and 11.5:1 0r 12:1 compression. On the fence with the cam. Might have to go custom.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
07-10-2015, 07:36 AM | #9 |
Only slight milling and slight compression bump. I have plans for a supercharger in the future that's why I went with the 260 and kept the compression pretty much stock. If your going to stay na go with the 255. I love this cam I had a crazy cam in my trans am and I lost all my low to mid power and made it all up top. This cam has a really nice curve with no torque loss
07-10-2015, 07:46 AM | #10 |
What you posted is what I'm hoping to achieve, maybe slightly better. I'd like to go 11.5 to 12:1 compression, but that will require probably 63cc chambers at least. I think I could still run the TSP 235/239, but just for giggles I put in my order sheet to Pat G with all my specs. Told him I wanted hard chop at idle, hard pull from 3k to the red line without the power dip that I am seeing in this TSP cam, and with better tq gains. I started my "what do you want out of this cam" with "I want a TSP 235/239 killer!"
Don't get me wrong. I love this cam. But if I can taylor my own cam to perform just a little better, and on PatG cam motion lobes, then I'm all over it.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. Last edited by Bodywerks; 07-10-2015 at 08:06 AM. |
07-10-2015, 08:56 AM | #11 |
Sounds like a good plan you can def achieve over 500 whp and over 450 wtq going that route. I have stock cat back I wonder if I would make over 450 wtq if I went aftermarket but I heard a lot of mixed reviews.
07-10-2015, 02:13 PM | #12 |
I was on the fence between the 229/236 and the 235/239 because I didn't want to loose that mid-range power/tq. But after seeing/hearing/feeling it in Simon's 1LE, I was sold.
I would love to have my tq number up some more for sure but there are compromises with everything in this life. That said I have 0 complaints. Once that crank speed starts spinning up, it bails hard all the way to 6.5K and the cam shake/rumble at idle with the larger profile is just flat out killer. I hope you find the 235/239 killer with matching hp/tq numbers in that custom grind. Then I hope you share it! @Simon - thanks man!
2014 1LE AGM - VMax TB - CAI - JRE Air Scoop - TSP 1-7/8 Headers - TSP 235/239 112 LSA - NPP - Apex 1.25 springs - JBA cables - tuned by Lashway Motorsports
07-10-2015, 04:11 PM | #13 |
[QUOTE=2K141LE;8526352]I was on the fence between the 229/236 and the 235/239 because I didn't want to loose that mid-range power/tq. But after seeing/hearing/feeling it in Simon's 1LE, I was sold.
I would love to have my tq number up some more for sure but there are compromises with everything in this life. That said I have 0 complaints. Once that crank speed starts spinning up, it bails hard all the way to 6.5K and the cam shake/rumble at idle with the larger profile is just flat out killer. I hope you find the 235/239 killer with matching hp/tq numbers in that custom grind. Then I hope you share it! what are your numbers? |
07-14-2015, 11:23 AM | #14 |
Just got specs back and order placed:
232/240 .654/.626 110+2 Lots of intake lift in a short duration, should improve midrange a bit.
2015 SS/RS/1LE
