11-15-2019, 11:37 AM | #1 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Physics Discussion
When considering a dyno run everyone says you average 20% parasitic loss for the drive train. Cool, I agree. 300 crank HP motor makes 240whp. So then for a 600 crank HP motor is should only take the original 60hp to spin the trans drive shaft and related components right?
But this is where it begin to defy the laws of Physics. People still argue it takes 20% so a 600 CHP motor would lose 120hp and only show 580hp? How is this possible? Nothing changes, where is the mystical HP gremlin eating all this HP? Now, consider this! If an alternator takes 15hp to run and you take it off the 300hp motor and put it on the 600hp motor why does it not take 30hp to run? this argument could be made with anything you attach to the motor right?
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
11-15-2019, 04:40 PM | #2 |
Drives: 2SS/RS Join Date: Sep 2008
Law of motion. The faster something moves or spins the more friction that is built up. The more friction, the more power needed to overcome said friction.
When it's all said and done, a 600hp engine will create twice as much friction and rotational forces among all moving parts and tires as a 300hp engine. Twice as much friction means you need twice as much power to overcome said friction. |
11-16-2019, 10:21 AM | #3 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
(Hip shot explanation) The 20% plus or minus something is a "wide brush". Over the span of different torque outputs measured on a typical car engine pull, the loss empirically observed is in the area of 20%. You can not extrapolate the torque numbers by multiples and expect any accuracy.
11-16-2019, 01:06 PM | #4 |
Drives: 2014 2SS/RS Join Date: Jan 2018
And 600 - 120 is 480
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
11-16-2019, 01:09 PM | #5 | |
2014 2SS/RS LS3/M6
11-16-2019, 03:38 PM | #6 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
They call it the rule of thumb. Might be less than 20% but it is a good general estimate.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
11-16-2019, 06:19 PM | #7 | ||
Here's one I found with a quick google search that goes in depth about the whole "rule of thumb" thing and what actually causes the power loss. http://www.superstreetonline.com/how...in-power-loss/ They even state the same thing I did above. Quote:
11-16-2019, 06:22 PM | #8 | |
Moderator.ca
Consider what is actually happening in the system, at a moment frozen in time. The power may as well be torque (since power at a given moment equates to torque). More than that, torque is effectively a rotating force. What this means is that the drivetrain components are transmitting force from one part to the next. Follow so far? Alright, so that force transmission happens because of friction. And friction is proportional to the forces applied. Its a touch more complicated that that, as it involves calculating the normal forces at the tangent angles between gears and such. But the end result is that as you increase power, you increase the friction within the system.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
11-21-2019, 04:05 PM | #9 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
So, theoretically you should be able to take you whp numbers from the dyno, divide by .8-.85 and get a decent estimate of your crank hp numbers?
Cool...
