#Camaro6
Old 04-06-2021, 05:35 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
HP Difference: 93 v. 104 u/l octane?
I'm going to have these two tunes prepared for my car, but I have never tested any engine and compared pump gas to race gas hp. In this case, it's 93 v. 104u/l. I wondering if anyone here has or knows a shop that has performed such tests? Do you have an opinion of what these dynos would show?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 04-06-2021, 07:49 PM   #2
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
The car from the factory is tuned for 93. 100octane 200octane 500 octane won’t make any difference. Considering that your car is stock tune. But looking at your profile seems like you have tuned for your mods. Higher octane really just allows more timing. In tune means more HP.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 04-06-2021, 08:05 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d guess 40+ WHP by running race gas. Should be good for a few degrees of timing for sure.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 04-06-2021, 09:54 PM   #4
crosive
Drives: 18 zl1
a shop local to me claims 30-40 whp gains on their dyno on the lt4 engine regardless of car or transmission just by popping some 100 in there, but doesn't see any difference from 100-110.
I don't have any reason to not believe them, but it does seem to be a bit proud
crosive is offline   Reply With Quote
Old 04-06-2021, 10:14 PM   #5
Joshinator99
LT4’s see some knock retard on 93 bone stock, so doesn’t sound unrealistic to me IMO.
Old 04-06-2021, 10:36 PM   #6
95 imp
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike
IMO, you should be running higher than 93 octane in your motor. Keep adding octane until the KS stop picking it up. 1 gal of xylene to 10 gal of pump gas will raise octane 2 points.
(91-->93. 93-->95)
Or, obviously, 5:1 will raise it 4 points
Keep adding a gallon to creep up on the actual amount you need to stop knocking and add 1 more point for insurance and that's what your engine should be drinking.
Any higher octane than necessary is a waste of money, fuel, and lowers power.
95 imp is offline   Reply With Quote
Old 04-07-2021, 12:45 AM   #7
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Add a flex fuel sensor, tune for 93 and E85, and call it a day.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 04-07-2021, 07:16 AM   #8
Jeb114
Jeb114's Avatar
Drives: 2021 300
Gasoline does not create Horsepower. It supports the Horsepower the engine has built into it. Thru ignition.
Jeb114 is offline   Reply With Quote
Old 04-07-2021, 11:52 AM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
These results are on a Gearhead Automotive Performance tuned 2016 Ford twin-turbo 3.5L V6. We'll put it on the dyno soon and find out:
'20 ZL1 1LE A10,
