Old 12-10-2018, 04:58 PM   #1
redcoats1976
pinstripe lines in paint.
i recently removed the stripes on the rear spoiler of my camaro.no ghosting,but at certain angles you can see lines where the stripes used to be,almost like the paint is thicker or thinner in that area.can anything be done with this,or will it eventually take care of itself?
Old 12-10-2018, 05:54 PM   #2
jlcustomz
jlcustomz's Avatar
Drives: 83 el camaro
Always try gentlest method first such as a light buffing compound.
If you really can see a height difference in paint, then I might start with 1000 grit wet or dry sandpaper on a block working up to finer grits, which will then need 2 or 3 stages of buffing to bring back clarity.
jlcustomz is offline   Reply With Quote
Old 12-10-2018, 07:40 PM   #3
redcoats1976
thanks...ive heard the paint on the 5th gens is rather thin so i have been unsure how much to sand.
Old 12-11-2018, 05:41 AM   #4
BRZN
BRZN's Avatar
Drives: 2012 1LT
I can see the same on my 5th gen Ashen Grey Metallic where I removed the skunk stripes. I too have been told how thin the paint is on these cars. Since the marks can only be seen in certain angles, in certain light, I've left them alone. I do have experience wet sanding, but don't feel it's worth the risk. Polishing won't remove the marks but does help bring the appearance of the paint the same where the stripe was to the rest of the panel.
BRZN is offline   Reply With Quote
Old 12-12-2018, 01:00 AM   #5
rdanzel
Drives: 2010
I would try using a polishing compound since it is less abrasive than rubbing compound.
rdanzel is offline   Reply With Quote
Old 12-12-2018, 04:12 PM   #6
redcoats1976
already using polishing compound and random orbital polisher,even tried a little compound.no go
