03-26-2020, 03:23 PM | #1 |
Airbag Light On After Stock Seat Swap
Last week I swapped out my stock 2010 black leather seats in favor of some adrenaline red seats out of a 2015 model. The airbag light is coming on. I removed the seats and checked the connectors and everything is plugged in. It looked to be a pretty standard swap. Both seats underneath look identical. I don't see anything that could be switched besides the heated seat module. Any help is greatly appreciated.
03-26-2020, 04:02 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Have you looked at any of the wires? I had my airbag light on in my other car and the harness itself had been stripped from what looked like the back and forth motion of the seat from being adjusted. It must have snagged on something one time and set the light off. So I soldered it back together with some extra lead to give it more room
03-26-2020, 04:12 PM | #3 |
Drives: 2013 SS 1LE Join Date: Nov 2011
If you do a search on here, there have been threads posted.
03-26-2020, 04:26 PM | #4 |
I was under the impression that this was not a simple plug and play swap for the 2010-2011 models. Something about having to add a resistor inline or a change to the harness to avoid this exact issue.
Search around, I know there are some threads about this. I know there was a change in the later models that made the swap to a 2010/early 2011 model a little bit more work. Almost certain it is a resistor fix.
03-26-2020, 04:57 PM | #5 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Don't know if this might be the issue, but did you unplug the battery negative before disconnecting the sensors?
03-26-2020, 06:20 PM | #6 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Can you not swap the oe airbag junk over to your new seats?
03-26-2020, 09:44 PM | #7 |
Matthew, check out post #24 in this thread. You will likely need to read the entire thread for proper context, as it is for a Recaro swap, but should still apply. Apparently this is only an issue on swaps into a 2010 model year. Hope it helps:
https://www.camaro5.com/forums/showt...=365033&page=2 "The way to get around the 2010 airbag issue is this: On the passenger seat on the l/h rail is a sensor held on with one Philips screw. It has 2 light blue wires going to it. You need to transfer that sensor. There's even a screw and locating hole provided in the same spot on the new seat base. The '11 up cars do not have that sensor. They have a orange to blue circuit loop that goes to the seat belt sensor. On the 2010 cars the blue wire splits and creates an additional circuit loop including the sensor. You simply need to splice into the blue wire, incorporate the sensor and then put the pin in the corresponding point on the plug. If you look at your original seat plug it'll be clear; there's one extra blue wire pin. That's the one coming from the sensor loop."
03-27-2020, 01:37 PM | #8 |
Drives: 2010 SS Join Date: Feb 2016
Matthew, follow the advice in the thread above, I had to do the same thing on my 2010. I also had to put my original 2010 seat belt connectors on to my leather 2012 seats. For some asinine reason, GM decided to change the belt latch somewhere between 2010 and beyond so the belt connector would not go into the latch. I swapped the seats then had to pull them back out and swap the seatbelt latch on each side too.
White 2010 SS
Huron twins 4l80 conversion |
03-27-2020, 03:18 PM | #9 |
Stigs Bahraini Cousin
My guess is if the battery wasn't disconnected it triggered the light when plug got disconnected. Have it scanned and reset.
2015 CAMARO 1LE
03-27-2020, 03:39 PM | #10 |
Problem is that the 2010 models used a sensor and seat belt setup that changed after this model year. Some people have success doing like greenhornet says and just transferring all your existing bracketry and sensors from the 2010 seats to the newer ones. Either way, that thread I posted has some good info. I'm sure there is more out there.
