09-28-2014, 08:58 PM | #1 |
Drives: 2014 Red Hot Camaro 2SS 1LE Join Date: Jan 2013
Heat coming through vents when air is off
Does this happen to anybody else? When driving with the windows down and AC off, I find myself having to close all the vents because hot air keeps coming through. Fan is turned to off, Temp turned to cool (Which shouldnt matter anyways)
09-29-2014, 09:32 AM | #2 | |
Drives: 2012 Camaro ZL-1 SIM Join Date: Sep 2008
You are feeling the forced air coming in while driving. With the HVAC turned off, you can still press the recirculation button. This will prevent the issue.
09-29-2014, 09:37 AM | #3 |
09-29-2014, 09:48 AM | #4 |
Drives: 2014 Camaro 1LT RS Join Date: Sep 2014
This happens to me as well, I usually turn on the fan set to very low speed and then just adjust the temperature.
09-29-2014, 11:42 AM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Or.....just set vent to floor.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
