Old 11-19-2020, 05:10 PM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
What are these?
What are these sitting on top of the mufflers? And what do they do?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 11-19-2020, 05:14 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
NPP rpo exhauast option.
Google 5th Gen camaro NPP exhaust
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 11-19-2020, 08:31 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Just what Killer said. NPP exhaust valve.
HOJO is offline   Reply With Quote
Old 11-19-2020, 09:11 PM   #4
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
So I just found the forza controller that allows the driver to control the valve. Anyone have one of these?
Old 11-19-2020, 11:35 PM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Yes, I have the 2 mode one ( factory mode or always open) E1 is marked on the controller and has a 2 button fob. There's also a 3 mode one (factory mode, always open, always closed) E2 is marked on the controller and has 4 button fob. Which one do you have?
camguynj is offline   Reply With Quote
Old 11-20-2020, 06:34 AM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Like others said it's the exhaust valve for your NPP exhaust. In other words it's the volume control for your exhaust.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 11-20-2020, 06:59 AM   #7
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I have a manual 3-way switch wired in so I can go always open, always closed, or normal operation.
Old 11-20-2020, 07:34 AM   #8
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
How quiet is closed?
Old 11-20-2020, 07:39 AM   #9
camguynj
camguynj's Avatar
Same as factory mode between 1,000- 3,000 rpm when the exhaust flaps are kept closed
Old 11-20-2020, 08:13 AM   #10
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
I have the 3 way Forza and it works. Open, closed or factory settings. I leave early and always close the valve. Its is still a bit loud till it idles down after than its pretty quiet. The car will start with the bypass open and will not close until you get to about 20 MPH or for me around 2 gear. If you get on it it will open. I leave it open all the time but close for starting in the morning. If I have the back seat down to hold my fishing rods and am on a long trip sometimes I will close it. Its worth getting and the instructions on installing it are spot on.
JD555 is offline   Reply With Quote
Old 11-20-2020, 08:41 AM   #11
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I would be looking at the manual version so I could leave it closed for cold start. Starting in the underground garage is like putting an amplifier on an already super loud exhaust. I love my NPP and want to keep it. I also don’t want all of my neighbors in the apartment to complain to management about me.
Old 11-20-2020, 09:15 AM   #12
Vegas Bound
Drives: 2013 Sparkly Red One
Hanger brackets.
Vegas Bound is offline   Reply With Quote
Old 11-20-2020, 10:08 AM   #13
larry_g
larry_g's Avatar
https://www.camaro5.com/forums/showp...44&postcount=9
https://www.camaro5.com/forums/showthread.php?t=565292
Old 11-20-2020, 10:43 AM   #14
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I am afraid of wiring the system without the forza, not any level of electrician here and I am pretty sure I would get something crossed.
The location of the toggle switch is awesome and definitely doing that!
