05-17-2016, 11:25 AM | #1 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Finally tuned my 1LS
Using HPTuners and working with Overkill Will, we've been doing some tuning on my 1LS. Probably been about a month now, but I wanted to wait before creating a thread.
There's been a lot of logging and sending data back and forth, trying new tunes and working through things. Still seems to have some KR that we are working out, but damn this thing has woken up. This is probably what the Vitesse TC people keep talking about, but we made adjustments to the throttle through the tunes, and it's feeling really nice. Overall, been very happy working with Will on yet another car. Highly recommend him in the W-body world, and now I definitely recommend him for anyone else with the LFX.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-18-2016, 03:43 AM | #2 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Agree 100%! Will is a genius with this engine. He has been doing my tuning for the last few months and i couldnt imagine going with anyone else.
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
05-18-2016, 09:58 AM | #3 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
Indeed Will is by far the best remote tuner out there
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
05-18-2016, 11:17 AM | #4 |
Yeah, he's been great to work with. Still just chasing down some bad KR at WOT. About to send some more logs over to see what can be done
05-18-2016, 12:03 PM | #5 |
Drives: 2010 Camaro Join Date: Nov 2009
Will is by far the best we have seen to date.
What is most likely causing the KR is the oil mist entering. The Elite E2 and E2-X dual valve with cleanside is really one of the only proper ways to stop this as most catchcans only trap a small amount of what passes through them (15-30% max for most), and as the LLT has 11.3:1 CR and the LFX 11.5:1, even a small amount of oil most will result in detonation and cause knock retard. Will can verify this as well. Let us know if you need guidance and you will also need to clean all the oil already pooled in your intake manifold out or it takes a few hundred miles of driving once the proper E2-X system is installed to clear it. Make sure you use a rag or paper towel to sop up the oil in the depression GM cast into all of the V6 intake manifolds just inside the opening where the throttle body bolts on. It will have plenty in there and it most be cleaned out. Try it, we guarantee an improvement with out latest app. 95% effectiveness in separating and stopping this ingestion. |
05-18-2016, 12:22 PM | #6 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Well I got Will as my tuner and Elite Engineering's E2-X as my catch can so I'm as happy as can be. Will really is the best in the business if you ask me!!
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
05-18-2016, 12:23 PM | #7 |
great stuff to read. I couldn't handle the want anymore.. so I pulled the trigger. And the wait begins.
05-18-2016, 12:23 PM | #8 |
He's addressing that issue with mine as well but I think he has it licked. Gotta run the E85 out and refill with gasoline to verify.
05-18-2016, 01:46 PM | #9 | |
I've had a form of a catch-can on this car since about 500 miles (RX, and then Apex). I would hope it's not that dirty, but I guess I can dismantle the UIM on a free weekend to verify.
05-18-2016, 02:10 PM | #10 | |
here ya go! http://www.eliteengineeringusa.com/c...oil-separator/
Sponsors:
05-18-2016, 03:09 PM | #11 | |
Do you have this installed?
05-18-2016, 03:19 PM | #12 |
Yes I do.
Sponsors:
05-18-2016, 04:01 PM | #13 |
Did you have to buy the extra hose and caps that weren't included?
05-18-2016, 04:05 PM | #14 | |
The hose it came with.
Sponsors:
