Old 07-08-2014, 01:13 PM   #1
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
OEM ZL1 wheels on SS
I read some conflicting threads, so I want to confirm.
Will the OEM Zl1 wheels/tires fit an SS?
Front - 20x10 with 285/35/r20 Goodyears F1
Rear - 20x11 with 305/35/r20 Goodyears F1
Some people suggest bulging, issues with handling etc.
Will they work on an SS (not lowered)?
ajp is offline   Reply With Quote
Old 07-08-2014, 03:19 PM   #2
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Yes, they will fit just fine. You might have to tie back the rear brake cables with a heavy duty zip tie though.
As far as bulging? They are an aggressive fitment so the fronts are right at the top fender line. Some like that some prefer them to be tucked in more.
Handling? They handle great!
I have BFG Rivals rather than the Goodyear F1s and 285s in the back rather than the 305s but this pic should give you a pretty good idea what they would look like... Name:  20140613_215920.jpg
Retro69 is offline   Reply With Quote
Old 07-08-2014, 04:29 PM   #3
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
Yes, they bolt on with no issues at all. Like they said above, check your parking brake cable...not all of the cars need it tied back but some will.
If you want to save some $$ and put it towards the tires, we have our ZR28 wheel, in the same finish and sizes that look very nice on the cars!
Anthony @ LG Motorsports is offline   Reply With Quote
Old 07-08-2014, 10:04 PM   #4
ajp
ajp's Avatar
Thanks all - that helps.
Love the ZL1 wheels!
Old 07-09-2014, 08:56 AM   #5
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
Nothing new here, but confirmation the ZL1 setup with the Goodyears fit fine. I did have to ziptie the break lines. Mine is lowered 1.4".
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
Old 07-09-2014, 09:31 AM   #6
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
hey also fit on the V6 models as well no issues.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 10-18-2019, 08:46 PM   #7
ldeardorff
ldeardorff's Avatar
Drives: 2011 Camaro 2SS
Did you use hub centric rings for the change of bore on the wheels?
ldeardorff is offline   Reply With Quote
Old 10-18-2019, 09:59 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Running 6th Gen 1LE wheels with 285’s all around with no issues. Same basic wheel.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Suede Steering wheel, short throw shifter. Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 GS Calipers, PAFDT Solid Cradle bushing, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
