02-25-2014, 05:59 PM | #1 |
Drives: 2010 Camaro SS, 6-speed manual Join Date: Nov 2012
BMR vs. Pfadt Springs?
So I'm wanting to go lower! The stock ride height is too high for my taste, as well as most people apparently! So I've looked into several brands and two stood out more than others: Pfadt and BMR. I do not have the money for coilovers currently... Maybe some day. But for a little lower stance now...
The Pfadt website is really good. Very informative and the prices are reasonable. The Pfadt springs are a 1.25" drop if I'm correct? On the Pfadt website, it states: "Pfadt Lowering Springs have been engineered to optimize the factory damping with a 1 to 1.25 drop and increased spring rate. Lower your Camaro more than 1.25 inches and you'll find that the factory dampers no longer work properly, resulting in a bouncy ride." On the other hand, BMR springs drop the car 1.4" and are a bit less pricey. However, according to Pfadt, lowering it 1.4" will be stressful on the factory struts? I'm not sure that the 0.15" difference is even that noticeable... But still.. So my question is.. Which is the best option? I would like my car as low as I can get it on springs... but not at the total cost of ride quality.. and not at the cost of damaging the factory parts to the point of early replacement. Thanks in advance! |
02-25-2014, 06:05 PM | #2 |
Drives: 2010 CGM 2SS LS3 Join Date: Oct 2013
Pfadt just posted that they are closing their doors, so you better hurry if you want to find some from a vendor that might still have them in stock.
I have the BMR 1" springs, and really like them. I've lowered several cars over the years and these springs ride and handle the best in my opinion. Definite thumbs up for the BMR springs |
02-25-2014, 06:15 PM | #3 | |
02-25-2014, 06:25 PM | #4 | |
Received a PM about that as well. I had no idea. That's no good. Well then does anyone recommend anything other than BMR? |
02-25-2014, 07:06 PM | #5 |
02-25-2014, 09:11 PM | #6 |
Drives: '69 SS Convertible Join Date: May 2009
I would do either BMR or Hotchkis springs. I had Hotchkis prior to my coilovers and they rode well IMO.
Build Journal |
02-26-2014, 09:00 AM | #7 |
Drives: Race Car Join Date: Sep 2009
BMR offers a 1.0" drop set, a 1.4" drop set , or even a raked 1.4" (front) & 1.0" (rear) set!!! Plus, they have a lifetime warranty against any "Sag" to the original purchaser. And here is the REALLY good news:
http://www.camaro5.com/forums/showthread.php?t=344278 |
02-26-2014, 10:55 AM | #8 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Those who have the Hotchkiss springs say they are the smoothest ride out of all the lowering springs. If I wasn't saving for coilovers, I'd probably go with Hotchkiss.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
02-26-2014, 07:45 PM | #9 |
Pretty much everyone says to save for coilovers... :l I suppose that's what I might do... That way it would be adjustable.
02-26-2014, 08:20 PM | #10 |
Drives: 2011 Camaro Join Date: Dec 2012
There is also LSR Performance:
LSR Performance lowering springs will lower the vehicle 1 inch in the front and 1 1/4 inches in the rear for a more level ride height and better weight distribution. http://www.lsrperformance.com/lsr-st...g-springs.html You can email me at tim@lsrperformance.com if I can help you with anything. Best Regards, TJ |
02-27-2014, 07:55 AM | #11 | |
02-27-2014, 08:26 AM | #12 |
02-27-2014, 09:25 AM | #13 |
Drives: 2010 M6 2SS Join Date: Mar 2011
Love my car on Hotchkis with 1LE dampers.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
Thread Tools | |
