09-12-2018, 09:10 AM | #1 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Key cutting
finally happened - switchblade opened while attached to my belt loop, and I sat on it, broke. Never found it, but ordered a replacement - now to get the blank cut. I work during the day, wife dosent really like driving my Camaro, but I remembered they gave me these tags when i bought it new, saying if I ever needed a replacement, or cut, it can be done from this tag... So, thought I would have my wife drop off the blank, and the tag so I can pick up later. I honestly dont see how, but thought Id run it bt everyone to see if its been done before...? thoughts?
09-12-2018, 09:29 AM | #2 |
Drives: 2014 2SS/RS Join Date: May 2015
the dealer probably is the one who will need to cut it from the tag. they can also use your VIN to get the key code and cut it.
09-12-2018, 11:13 AM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Bend over
Seriously though, best of luck
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
09-12-2018, 11:34 AM | #4 |
[QUOTE=TheFlyingBananaSS;10308938]Bend over
Seriously though, best of luck [/QUOTE I dont go to the dealer for the petty things - thats like buying tires from the dealer... There are so many locksmiths around that can laser cut |
09-12-2018, 12:18 PM | #5 | |
[QUOTE=kmarshall2121;10308963]
but can they pull the code from a vin? the tag they might be able to have access to the software... and they definitely can make a copy from another key. |
09-13-2018, 10:05 PM | #6 |
Drives: 2SS/RS Join Date: Sep 2008
Some locksmiths can easily make you a copy if you have the key part but like you said, you never found it. Using the tag requires a programmable cutter so don't be surprised if you have to go to the dealer. How many locksmiths are going to spend thousands of dollars for a programmable cutter that can only cut GM keys?
