Rick@Livernois
Old 09-17-2009, 02:51 PM   #1
Cruzintexas
Cruzintexas's Avatar
Drives: 2010 Camaro LT2/RS
Help with Vibration
Car starts a light vibration in the steering wheel at 30-35 and contiues as speed increases. They have changed out a set of tires already. It has the 20" polished rims. at 74-77 it is anoeying as can be. drove another members SS and it was smooth as glass. I guess you can see in the sig mine is a 2ltrs. Steering wheel goes up and down. I had my GPS mounted to the windshield on a recent trip and at hwy speeds it moved so much it was hard to read.
Thanks for any input.
Steve
2LT/RS Black on Black 20" polished Wheels!
Its all Hers
delivered 07/10/2009
Cruzintexas is offline   Reply With Quote
Old 09-17-2009, 04:13 PM   #2
ffrcobra_65
Ok, since they have already changed out the tires, we can probably safely assume that they did a high-speed re-balance and all is good. Since you are feeling it in the steering wheel, next to check would be the front suspension and steering components. IMO, steering wheel bouncing up and down, either wheel balance or suspension.
Old 09-17-2009, 09:33 PM   #3
tmc
tmc's Avatar
Drives: 2010 Camaro SS/RS
I had the same problem. All suspension and drive train components were in good shape. The dealer force ballanced the wheels and it when away. Force ballancing apparently simulates the load of the car on the wheels when it is ballanced.
tmc is offline   Reply With Quote
Old 09-17-2009, 10:51 PM   #4
jimpfromwv
jimpfromwv's Avatar
Drives: 1968 camaro ss, 2010 camaro1ss
If my car sits overnight it has a vibration for the first 5 to 7 miles then it smoothes out, its like it has bias ply tires on it?
jimpfromwv is offline   Reply With Quote
Old 09-18-2009, 12:27 AM   #5
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
My car does the same thing if I take off in it early in the morning, now that the nightime temp has been getting down to 50 degrees. It's like the tires are flat spotted from sitting all night. Once I go a couple of miles and watch the tire pressure come up a couple of pounds it is gone for the rest of the day.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 09-18-2009, 05:05 AM   #6
jbsrace1
jbsrace1's Avatar
Drives: 2010 2ss
I would have the tires balanced again. The factory balance on mine was done with counter balance on every tire. Meaning whoever balanced them missed the first time and had to add weight on the opposite side to make up for it. Instead of pulling the weights and redoing it.That always aggravates me but I see it allot.
Another thing is these cars come with Summer only tires.
As it gets colder there will be allot more people with vibrations an traction complaints.
jbsrace1 is offline   Reply With Quote
Old 09-18-2009, 07:40 AM   #7
Cruzintexas
Thanks for all the input! Everything helps. The vibration does not go away after it warms up. Tire pressures stay good I monitor from the cockpit while driving. They use a road force balencer. Next they are running a vibration meter from GM. My dealer has never used it so another dealer is coming over saturday to help with that. They started a case with GM and thats what they wanted next? The sticker says 36psi for the 20" Pirelli's. What are you all running?
Thaks
Steve
Its all Hers
Old 09-18-2009, 01:53 PM   #8
tmc
tmc's Avatar
I do still experience a small vibration untill I get the tires hot. Unfortunatly, my car in the garage more than the road.
My pressure is curently 35psi. The OnStar monitoring that emails when there is an issue also recommends 36psi.
Good Luck.
Annoying Vibration with After Market Exhaust cshaw2049 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 09-12-2010 03:14 AM
Wheel Vibration tmc Wheels and Tires Talk Sponsored by The Tire Rack 39 08-20-2009 09:14 PM
What happened to my Camaro at the dealer? OHIOSS 5th Gen Camaro SS LS LT General Discussions 35 08-03-2009 07:44 PM
Any other LS3 owners have a bad vibration sound at 1500 RPMs Johnyoder Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 07-23-2009 04:25 PM
Normal Transmission Vibration??? ravensjeff V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 06-08-2009 02:16 PM
