![]() Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Crate motor with cam swap or keep the factory motor and do heads/cam swap?
Ok guys, I am getting ready soon to upgrade my cam/heads etc but I have run into a dilemma and need some input and before you say do it yourself I just had major shoulder reconstruction so that is out.lol
Anyways, after getting pricing on a vvt cam swap with afm delete the price is looking to be about $4,500 with everything needed labor and all. My question is would it be better to just buy a new LS3 long block from GMPP for $5,200, swap in a low lift cam swap before I put it in the car and then drop it in for around 6k in parts plus labor and then sell the factory L99 whole motor? If you guys have kept up with my other posts I have a GPI ported TB and intake so effectively I would have a whole other motor I could sell minus fuel rail and the normal stuff when putting in a motor. Labor to drop in new motor is pretty much a wash between a cam swap while motor is in car. Is it easier to install a whole new motor than to do a cam swap in the 5th gen? On top of it all I would have a new motor with zero miles instead of my L99 bottom end with 50k on it. Just looking for some input from you guys who have done a cam swap or maybe just put in a whole new motor but the cost difference for a whole new crate motor and then just adding a lower lift cam is interesting. On a side note I would just get the LS3 long block with the hotcam but that cam really isn't the best for what I want. Figure it would be best to get the base LS3 and then go from there if I went the crate and cam swap route. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I wouldn't replace the engine at 50k. There's a lot of miles left on that thing if it's been treated right. The thing is you get into a lot of little things when you replace the engine, things you don't even think about like oh I need new engine mounts, torque converter bolts, flywheel bolts, and oh I forgot about coolant or I need to change the oil three times right off the bat. I would just do your heads and cam because I think you will be way off better in the long run.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
![]() ![]() Drives: 2011 Camaro SS Join Date: Jul 2019
Keep the original motor and do your heads and cam.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
