03-16-2020, 10:15 AM | #1 |
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Stock SS tires on 1le wheels?
Has anyone tried fitting the stock Ss tires on a set of 20x10 front and 20x11 rear wheels? Stock tire size is 245/40/20 Front and 275/35/20 rear. Just curious cause I just bought some 1LE wheels and might throw these tires on with a bit of stretch cause they have a lot of life left. Post pics if you have!
03-16-2020, 10:42 AM | #2 |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
I was in the same situation when I bought my new wheels in 1le sizes. I ended up putting my 275/35R20s from the rear up front and I bought new ones for the back.
03-16-2020, 10:50 AM | #3 |
What size did you end up buying for the rear? And you don’t think the stock tires as is would work at all? Thanks!
03-16-2020, 11:30 AM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
That tire/wheel combination won't work. Will stretch the sidewall too far to have tires work reliably. Will mess up how the tread contacts the road, too.
You'd be better off putting the rear SS tire on the front 1LE wheel like Drew did, and then getting as similar of a tire you can get to the stock SS tire in a size between a 295-315 width and a 30 AR on the rear. Or, better yet, try to find a used set of 4 matching tires that are the proper sizes for the 1LE wheels. There's usually a decent selection on here and even some floating around on other sites.
2017 SS 1LE.
03-16-2020, 01:17 PM | #5 |
Drives: 18 1SS/1LE Join Date: Jun 2018
I agree with the 275/35 on the front but not the rear, too wide. Ofr winter use I have a 285/35 on the 1LE wheel and it's perfectly fine so you can go 285/295/305 and either 30 or 35 in the rear. 305/35 might rub the fender liner and harness but that's easily corrected.
03-16-2020, 01:30 PM | #6 | |
03-17-2020, 06:42 AM | #7 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would go ahead and invest in new tires of the right sizes for the wheels you bought. You can advertise your stock tires on Craig’s List or eBay to sell them to a Camaro owner who is looking for used tires with good treadwear left. I know it is expensive but that’s probably the best solution for you now and I really think you will enjoy the car and new wheels/tires better too as it will make a difference in the ride and handling!
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
03-17-2020, 07:12 AM | #8 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
You can move the rear OEM tires to the front, it will fit the 20x10 wheels just right—your problem is what tires to get for the back 1) to meet the bare minimum requirements for the wheel you purchased, 2) to keep the front to rear sizing balance, 3) not to introduce a huge difference in traction and ride characteristics between front/rear.
The OEM Goodyear runflats do not come in a size (295/30-315/30) that is suitable for 1) and 2), and I wouldn't recommend buying another brand for the rear due to 3), the OE runflats have terrible wet behavior I've witnessed firsthand, coupled with great hot dry traction that is going to be difficult to match. For these reasons, I agree with LT4Greg, bite the bullet, get some proper tires for front and back and enjoy them long term. Sizewise you can go with the 1LE specs (285/30/20 front, 305/30/20 rear) that is a direct fit for the wheels if these are the OEM 1LE ones, or you can go a bit bigger like I did (285/35/20 front and 315/30/20 rear), you might even be able to make 325/30/20 work in the rear.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 03-27-2020 at 09:34 PM. Reason: typo |
03-27-2020, 08:59 PM | #9 |
Thanks a lot for the input everyone! I ended up getting a set of 305/30/20s for the rear and moved the original rear wheels to the front
03-27-2020, 09:15 PM | #10 |
I would though get some 285/30 20s for the front wheels when possible! The ride and handling will be better!
03-28-2020, 09:53 AM | #11 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
04-02-2020, 07:07 PM | #12 |
I’ve seen some guy on YouTube temporarily use the stock ss tires on some 20x10 20x11 wheels though and they looked pretty damn stretched
https://youtu.be/SfnoFNrszIg |
04-03-2020, 06:53 AM | #13 |
"Stretched" is a tire&wheel appearance that most people who specifically consider themselves "musclecar fans" have a hard time understanding, simply because it looks different from what they're used to seeing. Perhaps a wide wheel makes the tire look undersized to them.
It's easier to appreciate a little stretch when you're more into hard cornering than straight line acceleration - once you've settled on a tire size, stretching it a little improves its cornering capabilities. Somebody who understands stretch (within limits) would see wheels chosen to emphasize cornering with the appearance being whatever it ends up being (function over form). Norm
'19 WRX 6M (the family sedan . . . seriously) Last edited by Norm Peterson; 04-03-2020 at 07:04 AM. |
04-03-2020, 11:14 AM | #14 | |
I think part of the knee-jerk reaction to hearing "stretched tire" is what people think of when they hear "stretched tire." For me at least, first thing that pops into my mind are tires stretched so far there's a 1/2" gap between the rim flange and the sidewall. Sure, a ridiculously stretched tire has it's place in drifting because they want the excessive lateral stiffness, but there are those that do the same thing for a street car and say it's for performance. If that's what floats their boat for looks then I say go for it, but it bugs me when people do that and try to say it's a performance benefit. I personally don't consider mounting a tire within the manufacturer's recommendation to be stretched, it's more just the standard for a performance car.
2017 SS 1LE.
Tags |
1le, camaro, stock tires, tires, wheels |
