Old 02-25-2018, 05:24 PM   #1
Thunder70
Thunder70's Avatar
Drives: 2010 ss camaro
Ceramic coated headers with supercharger
Is anyone running ceramic coated headers with ECS 1500 KIT
Thunder70 is offline   Reply With Quote
Old 02-25-2018, 08:51 PM   #2
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
I am running them with a Whipple. No problems. What are your concerns?
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 02-26-2018, 07:16 AM   #3
Thunder70
Thunder70's Avatar
Wanted to know if the ceramic coating that looks like chrome holds up to higher temps from supercharger
Old 02-26-2018, 10:14 AM   #4
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
I got some from SLP back in 2010 and put over 20000 miles and no problems. They did discolor a bit but not bad. My twin turbo set up is tuning it white though, so I'm thinking I had the wrong place do theses. The SLPs came coated.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 02-26-2018, 10:17 AM   #5
mrimpala02
Drives: Black 2SS RS w/White Stripes
I had some coated that same finish. They did turn a bit after a while, but not bad. See pic from the sell.
http://www.camaro5.com/forums/showthread.php?t=476819
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 02-26-2018, 11:15 AM   #6
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
ARH Ceramic Coated Had them originally on SBE EForce had a bunch of oil dumped on them after Grenading. Got to admit cleaned up and held up well but finish ( bright/chrome silver) dulled a bit around Heads. Held up just as well on New Motor NA Still using them now with newly installed D1X. Still look the same as after Engine went. There has been no further dulling.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 02-26-2018, 11:38 AM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
it will dull overtime due to the high temps.
not running FI myself, but my headers were coated w/ Cerakote Glacier Black C7600. at the merge i can see a little discoloring, but i think its from road rash
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 02-26-2018, 12:19 PM   #8
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Heres a good pic of my Ceramic Coated Headers. At the time of this picture they have been on the car for 5,000 miles.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 02-26-2018, 12:51 PM   #9
Thunder70
Thunder70's Avatar
Thank you everyone
Old 02-26-2018, 05:25 PM   #10
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
The only coating that is a true thermal barrier is Swaintech White Lightning. Everything else is essentially a high temp paint for aesthetic purposes.
Unavowed is offline   Reply With Quote
Old 02-26-2018, 09:58 PM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I noticed a 40+degree difference with my Kooks coated (sorry, not sure which, but was their in-house go to in 2013), so I think you're observations are a little off. May not be as much as those, but it's sure better than just "high temp paint"....
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-01-2018, 10:44 AM   #12
xc_SS/RS
with the cerakote on my headers i can feel a huge difference in radiant heat. not sure where you are getting this info from because there are definitely other thermal barrier coatings available. Swaintech is one of the originals, but its certainly not the ONLY thermal barrier.
also, those manifolds look hideous. nothing like brown pipes!
2010 2SS/RS
