04-02-2016, 01:05 PM | #1 |
Drives: 2021 ZL1 1LE Join Date: Aug 2010
Procharger D1 belt slipping
Ok just installed 416 in the car. Have a Procharger D1. At 6000 rpm it starts slipping and losing boost. Gets worse the more pulls made on the dyno. Have a new belt on and tensioner as tight as possible. 2012 Procharger set up.
Any ideas? |
04-02-2016, 01:22 PM | #2 |
Call Procharger. They will probably tell you that you have the tension set wrong, and to be careful as you will damage the bracket, then you will be paying for a new bracket.
Belt size? Pulley size? More info?
Nick
Corvette Z06 -1200ish rwhp |
04-02-2016, 01:43 PM | #3 |
The Pulley is 3.8. Don't know the belt size . The shop working on the car said they were going to call procharger Monday.
04-02-2016, 01:47 PM | #4 |
I know a lot of PC people who had belt slip, kept tightening the belt, and then damaged the bracket/tensioner. So that is why I'm saying be careful.
Nick
04-02-2016, 01:48 PM | #5 |
04-02-2016, 03:12 PM | #6 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
12 rib?
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
04-02-2016, 05:37 PM | #7 |
04-02-2016, 05:45 PM | #8 |
Drives: it changes Join Date: Nov 2010
What make of belt, and what type of tensioner ?
04-02-2016, 05:58 PM | #9 |
04-02-2016, 06:08 PM | #10 |
2010 transformer
After you drove it did you re tighten it
04-02-2016, 06:10 PM | #11 |
2010 transformer
I haven't seen anyone hurt a bracket even with 1100 plus rwhp
04-02-2016, 07:45 PM | #12 |
I've seen several, in person, not even including all the ones online.
Nick
04-02-2016, 09:35 PM | #13 |
04-02-2016, 11:39 PM | #14 |
2010 transformer
Shorter belt?
