Rick@Livernois
Old 02-20-2018, 05:54 PM   #1
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
WTB 2014-15 Z28 left upper manifold heat shield help!
WTB left upper exhaust shield if anyone is putting long tubes on?
in this picture its on left side in the middle
could also use 6-7 bolts too
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Old 02-20-2018, 09:46 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
GM PN is 12629722 no price but the right side is only 42 bucks.
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Old 02-21-2018, 08:47 AM   #3
zman1969
zman1969's Avatar
I found that looking at some 2017 ZL1 manifolds these are almost spot on as Z28 manifolds but the collector is now 4 bolt instead of 2 but shields look same I got PM 12666097 and that list for over 206$ fot a piece of tin!
1969 RS Z/28 302
2015 Zl1
Old 02-21-2018, 12:16 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Wow!!!
Orange Krush II
Old 07-17-2018, 11:03 AM   #5
zman1969
zman1969's Avatar
still looking for left manifold upper heat shield
help?
1969 RS Z/28 302
2015 Zl1
Old 07-27-2018, 01:02 PM   #6
zman1969
zman1969's Avatar
OK I found this shield on eBay without the bolts that attach them does anyone have 4-5 of them they could spare
Please?
1969 RS Z/28 302
2015 Zl1
Old 07-27-2018, 02:40 PM   #7
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Pull one from the other side and go match it up at the parts store if you don't have any luck here
chuckie669 is offline   Reply With Quote
Old 07-31-2018, 05:14 PM   #8
zman1969
zman1969's Avatar
dealer wanted $8 a bolt for these! no lie
pass on hardware bolts I want them all uniform, I did find some that will work
1969 RS Z/28 302
2015 Zl1
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
