Old 07-31-2014, 05:40 AM   #1
rayers0423
rayers0423's Avatar
Drives: Camaro SS 1LE
Launch Mode
Anybody used this? Videos - Info??
rayers0423 is offline   Reply With Quote
Old 07-31-2014, 06:43 AM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
yeah....... it sucks. Youtube has a few videos and apparently the 14+ 1LEs have no lift shift as well, 13s do not
My experience with launch control: I guesstimate I used it 8-10 times. Out of those times ONCE it worked amazing where the car just launched like a bat out of hell. The other times the car will either bog or blow the tires away. I can launch the car better without it.
CamaroDreams76 is online now   Reply With Quote
Old 07-31-2014, 07:22 AM   #3
ITRIEDEL
Drives: 2013 CTS-V
This.
I've only used it 3 times and it was only on the first time it worked well... last two times, it just bogs and major wheel hop... Launch it yourself.
Now: 2013 CTS-V
Previous:
2014 Camaro 2SS 1LE
2012 Mustang GT 5.0 (bolt-ons)
2003 Nissan SER Spec-V
2008 Highland Green Bullitt
1994 Cobra 70mm Turbo (571rwhp)
1996 Mustang
2003 Mustang GT (bolt-ons)
1991 DSM FWD (2g hybrid)
1975 Chevrolet Camaro
1991 Corvette
1974 Chevrolet Nova
ITRIEDEL is offline   Reply With Quote
Old 07-31-2014, 08:09 AM   #4
rayers0423
rayers0423's Avatar
How taxing is this on the clutch?
Old 08-02-2014, 02:38 PM   #5
CamaroDreams76
Probably no more than you launching it yourself maybe less because of letting the clutch out quicker rather than slipping it. It is probably harder on your drivetrain. One way will be easier on something but harder on another.
Old 08-02-2014, 03:00 PM   #6
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
I did it once at the track and got massive wheelhop. No thanks. That's a great way to break a halfshaft.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 08-02-2014, 03:01 PM   #7
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
I've done it twice. The 1st time it was amazing and launched so hard, the 2nd time it bogged down.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 08-02-2014, 03:32 PM   #8
Synner
Drives: cars
I do not use parts breakage mode.
Old 08-02-2014, 07:36 PM   #9
thompstl1
thompstl1's Avatar
Drives: 2017 A10 ZL1
I've used it several times and I've found it to be a bit inconsistent... I never get a terrible launch, but it's rarely a great one. Turn the sound up on this video, and you can see I'm well through 1st gear before full power is transferred. So I'd sum it up by saying launch control is ok... but not great.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
thompstl1 is offline   Reply With Quote
Old 08-03-2014, 12:12 PM   #10
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Unless I've missed something, the no lift shift is only available on the ZL1 and ZR1. You can conduct a no lift shift in the 1LE but you need to be quick. The RPM's will continue to climb during that shift.
HOJO is offline   Reply With Quote
Old 08-03-2014, 12:41 PM   #11
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Originally Posted by thompstl1 View Post
I've used it several times and I've found it to be a bit inconsistent... I never get a terrible launch, but it's rarely a great one. Turn the sound up on this video, and you can see I'm well through 1st gear before full power is transferred. So I'd sum it up by saying launch control is ok... but not great. [url]https://ww]
Out of curiosity, what'd you trap?
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 08-03-2014, 06:34 PM   #12
thompstl1
thompstl1's Avatar
153 mph. Strong heads winds (12-17 mph) and hot! Best speed are always in the morning when it's cool. That speed is about right for a good running S/S with tune and CAI. I'm looking forward to running again this October, to see what the Long Tubes and high flows contributed... and with a little luck, not such a strong head wind! Embarrassingly, my wife's car (SLK-55 AMG) ran 158 mph bone stock!
Old 08-04-2014, 07:46 PM   #13
CamaroDreams76
No clue, I heard from a member of tri county Camaro that the 14s have a set torque cut that is used for no lift shift.
I originally thought it was for the cobalt SS/TC, ZR1 and ZL1. But then again you would probably know more than me considering you own a 14 and I don't.
