04-07-2018, 10:37 PM | #1 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
This evening's fun...installing DW300C pumps
Got a killer deal on a LPE duel pump and figured it was going to be pretty much maxed out for what I wanted. Didn't have $1000 to spend on a DSX AUX pump.
I started looking and found the DW pumps and gave them a call. Finally got a chance to swap them out and it was pretty painless. According to DW they supported 750 RWHP on E85 without a BAP on their CTSV. I'm running a MSD BAP, but probably won't use it unless its needed. I have $1173 total in the fuel system including FIC 1000CC injectors. |
04-08-2018, 08:36 AM | #2 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
Any concerns/plans about these potentially throwing a CEL for pulling too many amps through the FPCM?
04-08-2018, 11:36 AM | #3 |
04-09-2018, 09:45 AM | #4 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I'm very very interested in the outcome here. So is that a CTSV pump that you've upgraded? Because I thought the ZL1 was a single and I dont see the camaro listed as a compatible vehicle for the DW300.
Can you explain exactly what was reprogrammed in the FPCM? I've already updated my SS fpcm to the ZL1 settings and can hold 58psi to redline. Does anything else need to change?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
04-09-2018, 10:23 AM | #5 | |
It's a LPE duel pump which uses the CTSV pump. It comes with new wiring, CTSV FPCM, and other lines and whatnot from LPE. I got a great deal on the duel pump setup so that's the only way it made it cost-effective to upgrade the pumps from DW. |
