04-09-2018, 10:58 AM | #1 |
CAM INFO NEEEDED.
Hello out there all you cammed guys and gals, finally doing it and doing a cam swap on my 2011 SS L99. I was going to do the TSP 231/236 cam package with a 112 LSA and a 3200 stall converter but when I called TSP they said that is their "old" cam and the new one is 231/246 which he said is the same cam, just makes more power. Who doesn't want more power. So my question for you cammed folks is, who has this new TSP 231/246 or the old 231/236 which I see you can still get in their Camaro with a 3200 stall. What do you like about it and what do you not like about it. Pleas share any info you have on this setup. Thanks so much folks.
04-09-2018, 12:32 PM | #2 |
Drives: 2015 Camaro SS convertible L99 Join Date: Nov 2016
I have the tsp vvt3 231/243 113lsa and circle d 3200 highstall. I already had 3.91 gears install before the cam and converter. The gears will help in keeping the rpm on the car a little higher on cruise which it tones down the surging or loping(correct me if I am wrong). It drives great, and for the sound a resonated x pipe will help alot.
04-09-2018, 12:50 PM | #3 |
4000 stall will do awesone
04-09-2018, 02:49 PM | #4 |
Thanks JLGO, anyone else have any info on this setup for the TSP Stage 3 cam package with a 3200 stall?? Would love to hear from you guys. Thanks Bo, but I only need a 3200...I think 4000 would be to much for my daily...
04-09-2018, 03:55 PM | #5 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
I have the TSP 231/246 cam installed. However, being advertised as an LS3 cam..I'll bet you aren't going to find a ton of guys that have put it in an automatic. Most of them have probably went with the stage 3 VVT cam instead. I believe its specs are pretty similar.
That said, if mine was an auto and I had this cam, I would probably shoot for a 3600 stall in it. Just based off when the power hits. I'm sure it would be just fine with a 3200 as well.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
04-09-2018, 04:18 PM | #6 |
Drives: 2SS/RS L99 ABM Join Date: Aug 2009
You will not regret going big on a stall in a late model trans. 3600 minimum. You’ll barley feel a 3200 after a month
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
04-09-2018, 04:31 PM | #7 | |
Drives: 2011 2SS Join Date: Mar 2015
+1, I wish I had gone bigger
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
04-09-2018, 05:19 PM | #8 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
I have the stage 4 cam in a auto with a 4000 stall 3.91 gears the stage 4 235/339 627/624 on a 111lsa
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
04-09-2018, 07:01 PM | #9 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
I have the 235/239 in a manual, really pulls from 4K up. if it was me I would go with a 4000 RPM stall, 3600 minimum.
04-09-2018, 07:34 PM | #10 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Stage 3.2 VVT cam card
Idle https://youtu.be/lYk8EvUNE3c Pull https://youtu.be/Dv9XWV7MUW8 Has circle d 3200-3400 stall
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
04-09-2018, 07:43 PM | #11 |
Drives: 2011 Camaro SS Join Date: Feb 2017
I have the vvt 3.2 with 3200 stall, 3.91 gear and LT headers. I really like the way it runs and drives.
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats |
04-10-2018, 01:38 AM | #12 | ||
LSx FTW!!!
Do you have HP Tuners? If so, care to share your tune file with me? I'm having just a little cold and hot start issues. I'd like to compare tunes. Mine cranks a bit long...
04-10-2018, 02:47 AM | #13 |
My stall flashes to 5600-5700 on the dyno. its an 8" 5000
daily driver
04-10-2018, 04:49 AM | #14 |
Drives: '18 SS 1LE Join Date: Jul 2016
Good luck to you! Im in my garage right now working on my cam install. I went with the Texas Speed 229/244 cam in my LS3 so im not sure about your converter.
Good to know somebody is taking this on at the same time I am. |
