Old 02-29-2016, 06:04 PM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
18x11 ZL1 Reps with 325/45/18 Hoosiers
Since RaceStar makes inconsistent 17" wheels and the new ones won't be out until summer time I plan on going with the 18x11 ZL1 reps with 325/45/18 Hoosiers. I know several people have used this exact set up on here and fit without any issues but just want to double check before I get them. These tires are $267 a piece compared to $330 a piece for 305/45/18 Mickeys, and I like how wide and tall the Hoosiers are. I just want to make sure it'll clear and not mess with Stablitrak or traction control.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 02-29-2016, 06:06 PM   #2
damian559
damian559's Avatar
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-29-2016, 08:10 PM   #3
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
I'm also interested those tires also if they fit with no rubbing and if anyone has pics that would be awesome
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 02-29-2016, 08:37 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 SS Blue Ray Metallic
https://tiresize.com/calculator/
Front and rear tire heights have to be within 1in I believe to not trip the abs
Huronspeed turbo kit, BTR turbo cam, squash fuel system, dsmlights e85 tune - 816whp / 809tq
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-29-2016, 08:50 PM   #5
damian559
damian559's Avatar
This is with them on the car and he had the 18x8 up front too
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-29-2016, 08:51 PM   #6
damian559
damian559's Avatar
What happens if it trips the ABS?
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-29-2016, 09:04 PM   #7
fif_gen_powa
stabilitrak lights up, than you lose abs, traction control and power steering
same things happens when you pull the abs fuses like some do at the track to make sure traction control is truly 100% off
Old 02-29-2016, 10:29 PM   #8
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
Looks good man.
Need4speed_motorsports is offline   Reply With Quote
Old 02-29-2016, 10:45 PM   #9
damian559
damian559's Avatar
Will it go back to normal after I put my normal street tires back on?
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 02-29-2016, 10:49 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
How tall are the 325/45/18 Hoosiers?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-29-2016, 11:36 PM   #11
damian559
damian559's Avatar
29.5"
12.1 @ 117 (Motor)
Youtube Channel:
Click Here
Old 03-01-2016, 10:30 AM   #12
Drogers0416
Drives: 2010 Heads and Cam
looks good
What tire size are you running on your car it looks good in the sig. Does it trip any lights?
Drogers0416 is offline   Reply With Quote
Old 03-01-2016, 03:13 PM   #13
When you put your factory back on then itll go back to normal from what I know without tripping a light.
Old 03-01-2016, 04:44 PM   #14
fif_gen_powa
Tsw nurburgring wheels
18x8 +35 front
18x9.5 +40 rear
front tire 235/55-18 GENERAL G-MAX AS-03 28.2" tall
rear tire 305/45R18 Mickey Thompson ET street radial 28.8" tall
no abs lights or anything
