09-21-2022, 02:35 PM | #1 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Opinions please - headers with stock cats (yes, you read that correctly)
I realize there is a power limit to the stock primary cats (such as stock hp levels if you track the car all the time)...
But, for a car that doesn't see a ton of WOT, and will likely only see a maximum of 800-850 rwhp in the future... What do we think about fabbing the stock cats into some 3" connector pipes behind a set of long tubes? I don't think I've seen anyone do that, but I'm thinking about saving some money over buying a set of Gesi Gen 2's and just repurposing the stock primaries behind a set of long tubes. Would opening up the flow path to the cat with a large primary be of any benefit vs the tiny little 2.25" opening going into the cat on each bank in the stock configuration? In other words, where is the real restriction here? The stock cat itself or the tiny opening between the tri-y stock shorties and the stock primary cat? I think it would be interesting to see how a stock cat performs compared to a Gesi cat, if they were both in a set of 3" connector pipes after a set of 2" long tubes. We always talk about how restrictive stock cats are, but maybe a lot of it is due to the (relatively) tiny inlet and outlet in the stock setup, particularly when the gasses are so hot (and thus need more physical volume) closer to the head. Thoughts??
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
09-21-2022, 02:39 PM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Waste of time. The factory headers are far less restrictive compared to the OEM cat pipes. The most restrictive spot is from the header/cat connection to the cat. It necks down under 2" in that spot.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-21-2022, 02:52 PM | #3 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
No! Stock cats with long tubes on a supercharged vehicle is a recipe for cat failure and engine damage. Don’t be penny wise and pound foolish. Your ZL1 deserves better.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
09-21-2022, 03:58 PM | #4 | |
fo'shizZL1
So the flow path would be 2" primary to 3" merge-spike collector to 3" connecting pipe to modified factory cat with 3" inlet and outlet to factory catback (sans secondary cats).
09-21-2022, 04:01 PM | #5 |
fo'shizZL1
I'm not sure that's entirely true. If anything, it would present the stock cats with cooler gases. There is at least 1 guy running 800 through the stock manifolds and stock cats with no issues so far on a C7Z06
09-21-2022, 05:10 PM | #6 |
Stock manifolds are not long tubes. Re-read my response. Yes, it is certainly true. In any event, the issue has been discussed numerous times in past threads. Just trying to help avoid a known risk.
09-21-2022, 05:47 PM | #7 |
fo'shizZL1
For some reason, I am not explaining this properly. I have never seen any discussion of running long tubes with stock cats. If you could point me to one of the numerous discussions I'd greatly appreciate it!
09-21-2022, 07:22 PM | #8 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
If you are going to install headers then aftermarket cats would be the way to go. That’s my opinion.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
09-21-2022, 07:50 PM | #9 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Yep, get yourself some GESI Gen2 cats if you really want to run cats.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
09-21-2022, 08:26 PM | #10 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
You're explaining things perfectly, to me anyway, and i think you may be on to something. I believe there's more than enough objective evidence that no cats, with the exception of gesi gen2's will live in FI applications over 700ish whp. At Camarofest several years ago, toohighpsi told me that the stock cat strata was superior to anything else on the market - this was a few years before gesi gen2's were available. It would not be particularly challenging to fab a set of header connection pipes from a set of stock primary cats. Would they handle 850+ whp? It's possible. We already know nothing else, other than gesi gen 2's will. I think it's worth a try.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
09-22-2022, 08:18 AM | #11 | |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Since almost everything in the aftermarket is garbage, why not try the stock cat. Let us know how it goes. |
09-22-2022, 09:25 AM | #12 | ||
fo'shizZL1
Either way, that's what I enjoy about this hobby. To me, the fun is in the build and the tuning and learning things. I used to log almost every daily 30-mi one-way drive on my 5th gen. I'd make little adjustments until that thing was driving smoother than stock with a cam, Big gulp, 103, headers, etc. I'll probably fab up some stock-cat 3" connector pipes and see how it goes. The substrate of the stock cat is likely more restrictive than a Gesi substrate, but who knows by how much. If it fails, I can always buy some Gesi's and put those in there instead. Thanks for the input! When I get around to actually doing it, I'll post the results, good or bad.
09-22-2022, 09:42 AM | #13 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Catalytic converters need to be at their operating temperature in order to work efficiently. With long tube headers, they lose a lot more heat to the atmosphere than factory manifolds. You will not get your factory cats up to temp, and they will not function the way they do with OEM manfiolds.
There is also a risk you blow them out, they plug your exhaust, and you seriously harm your engine. This sounds like a recipe for disaster in my opinion. |
09-22-2022, 10:29 AM | #14 |
Drives: '20 ZLE Join Date: Jun 2020
HPE installed green cats with their package, and they seemed fine. However, I roasted them with my KongX and they could be heard whistling as I went down the track. So, we scraped them out before dynoing my current package.
Does anyone make a hi-flow cat that will survive higher hp levels?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
