#Camaro6
Old 06-19-2013, 11:25 AM   #1
jrh@lpe
jrh@lpe's Avatar
Drives: anything
L83 5.3L V8 Gen V direction injection engine images
We recently took delivery of our 2014 Chevrolet Silverado 1500 4WD with the 5.3L L83 engine. We plan to use this vehicle as a development vehicle for 2014 based truck products and also for initial development of our Gen V V8 products since the 2014 CK trucks are the first vehicles to get the new Gen V GM direct injection V8 engines.
The 2014 C7 Corvette will get a 6.2L version of this engine (dubbed the LT1) and I am sure the Camaro will end up with versions of this engine as well so I thought this might be of interest to Camaro5 forum members.
I will use this thread to post some pictures of the L83 related engine components and then also the performance testing results (dynamometer and acceleration testing) from the vehicle. The 2014 Silverado performed very well compared to the previous generation Silverado so this should be a good sign for the next generation powertrain in the Camaro.
Here is a link to a YouTube video of some of the testing and results as well (think of the video as the Cliffs Notes version of this thread):
jrh@lpe is offline   Reply With Quote
Old 06-19-2013, 11:27 AM   #2
jrh@lpe
jrh@lpe's Avatar
Drives: anything
Crankshaft related images
Here is an image of the L83 Gen V V8 engine cast iron crankshaft. 92mm (3.622") stroke, just like the previous engines. Weighs 53.8 lbs.
And here is the same crankshaft next to a Gen IV V8 crankshaft:
Old 06-19-2013, 11:28 AM   #3
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
I am looking forward to this engine, since the current 5.3L is highly modable and they can be beasts!!
Mikes SS is offline   Reply With Quote
Old 06-19-2013, 11:28 AM   #4
jrh@lpe
jrh@lpe's Avatar
Drives: anything
L83 camshaft
Here is an image of the Gen V V8 L83 camshaft next to a Gen IV camshaft (extra lobe that is wider than the others is at the back of the engine and drives the high pressure fuel pump):
Old 06-19-2013, 11:39 AM   #5
jrh@lpe
jrh@lpe's Avatar
Drives: anything
Silverado engine compartment
Engine compartment with L83 engine:
with intake removed but sound deadening material still over injectors and rail:
with sound deadening pad removed, showing injectors and rails and valley tray:
thermostat housing and engine coolant temperature (ECT) sensor now mounted in water pump assembly (no longer in cylinder head):
Old 06-19-2013, 11:40 AM   #6
KMPrenger
KMPrenger's Avatar
Very cool that you guys did gasoline versus E85 test runs, as these things are rated about 25 to 30 HP/TQ higher on E85. The dyno appears to show this difference as well. (I'm assuming the dyno results you have are just HP and not TQ?)
Can you not get a TQ reading? Apparently on E85 the TQ is rated at 416 which is pretty incredible. These new engines are going to be making some killer power. I'm betting the 6.2 will do 480 - 500 TQ on E85 with the stock tune.
Thanks for posting this.
Old 06-19-2013, 11:41 AM   #7
jrh@lpe
jrh@lpe's Avatar
Drives: anything
Vacuum pump
The L83 truck engine runs a belt driven mechanical vacuum pump in order to generate vacuum for the brake booster. The C7 Corvette will likely get an electric pump. I assume the Camaro will also go electric.
Here is an image of the pump (attached to the block on the driver side low in the accessory drive):
Image of vacuum line that goes from the pump to the brake booster:
http://www.lingenfelter.com/LPEforum...0&d=1371590957
Old 06-19-2013, 11:42 AM   #8
jrh@lpe
jrh@lpe's Avatar
Drives: anything
MAF sensor
The L83 engine runs an eight wire mass airflow (MAF) sensor. Gen IV engines had a five wire sensor with two wires are for the intake air temperature and 3 wires are for the mass airflow. The added three wires are for a humidity sensor.
Here is an image of that sensor in the Silverado duct work (passenger side):
Old 06-19-2013, 11:47 AM   #9
jrh@lpe
jrh@lpe's Avatar
Drives: anything
DI fuel pump
The L83 runs a mechanical fuel pump off of an extra lobe on the camshaft. The pump is mounted at the back of the engine in the valley. The pump is fed low pressure fuel by a PWM controlled electric fuel pump mounted in the fuel tank.
Here is an image of the mechanical DI pump as it sits in the valley of the engine:
During testing of the vehicle, we recorded fuel pressure levels in the high pressure side of the system of 425 psi to 2200 psi.
Fuel pressure in the low pressure (lift pump) side of the system ranged from around 40 to 90 psi averaging between 46 to 55 psi depending on the test.
Old 06-19-2013, 11:48 AM   #10
jrh@lpe
jrh@lpe's Avatar
Drives: anything
E92 ECM
Here is an image of the E92 ECM mounted in the vehicle.
Note the added security measures installed on the ECM (aka plastic ZIP tie). Ours no longer has a ZIP tie.
Here is an image of the new E92 ECM next to an E38 ECM (the ECM used in the 2007-2013 CK trucks) for comparison:
More inputs and outputs (I/O) and the E92 has the built in high voltage drivers for the direct injection injectors.
Old 06-19-2013, 11:50 AM   #11
jrh@lpe
jrh@lpe's Avatar
Drives: anything
2014 Silverado chassis dynamometer graph, stock on gasoline
Here is a chassis dynamometer graph of the truck as we received it. This is tested on our Dynojet 248 chassis dynamometer. The abrupt end of the data is due to the factory speed governor.
This is on gasoline (roughly 9% alcohol content according to the on-board alcohol sensor).
307 hp at 5200 RPM and 332 lb-ft at 4200 RPM at the rear wheels. OEM rating on gasoline is 355 hp at 5600 RPM and 383 lb-ft at 4100 RPM. Power is right where it should be, especially when you take into account that this is with the 6L80 automatic transmission.
Old 06-19-2013, 11:51 AM   #12
jrh@lpe
jrh@lpe's Avatar
Drives: anything
2014 Silverado acceleration testing results, gasoline
Here are some of the acceleration performance testing results when tested on gasoline.
Best on gasoline is 7.5 seconds 0-60 mph and 15.94 seconds and 90.75 mph in the quarter mile. 1/4 data is with NHRA roll-out.
Gasoline testing was with 1/4 tank of fuel. The truck weighs 5340 lbs with 1/8 tank of fuel and no driver. This is with the vehicle fully up to temperature as you would drive it on the street.
Truck specifications:
4WD, short bed, crew cab, 3.08 gear
Old 06-19-2013, 11:54 AM   #13
jrh@lpe
jrh@lpe's Avatar
Drives: anything
Stock 2014 Silverado vs stock 2010 Silverado
Here are some acceleration testing results compared to a stock 2010 Silverado 5.3L 4WD truck.
Both are 4WD, both have the 5.3L engine, both have the 6L80 transmission. The 2014 has a 3.08 and the 2010 has 3.42 axle. The 2014 is a crew cab, short bed. The 2010 is an extended cab, standard bed.
Old 06-19-2013, 11:55 AM   #14
jrh@lpe
jrh@lpe's Avatar
Drives: anything
2014 Silverado E85 vs gasoline testing chassis dynamometer results
The 2014 L83 engine is rated at 380 hp on E85 (vs 355 hp on gasoline) and 416 lb-ft on E85 (vs 383 lb-ft on gasoline).
We ran the truck down to about an 1/8 of a tank and then filled it up with E85. Pump E85 never tests at 85% alcohol since they have to dilute the alcohol itself with gasoline for transportation in order to make it no longer consumable by humans. Then we still had some fuel in the tank as well. So before switching to E85 the on-board alcohol sensor read 9% alcohol content and after switching it read 65% alcohol content.
Attached is a graph comparing gasoline vs E85. The speed governor has been removed in order to allow us to test to a higher speed on the chassis dynamometer.
On gasoline the peak power is 302 hp and 332 lb-ft and on E85 that increased to 321 hp and 355 lb-ft.
2015 camaro, 2015 camaro forum, 2015 camaro forums, 2015 chevrolet camaro, 2015 chevy camaro, 2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 chevrolet camaro, 2016 chevy camaro, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
