01-25-2011, 12:29 PM | #1 |
Drives: 2020 6.2 sierra 2022 zl1 camaro Join Date: Aug 2009
Battery Replacement
long story short.
i have read diff threads on dead batteries. dont want to go thru hassle of getting my car flat beded from storage to dealer in this snow. and dealing with the dealership bs. (took car 2 times 2 dealer and got deep scratch on front lip and door dings) ((yes they fixed it)).. so my question is does anyone know or suggest a good replacement battery? what brand? i was looking at odessey and optima..... i found an odessey model number for my 2ss but not for optima, does anyone have a model number for a battery made by optima to use with 2ss? thanks in advance!!
______________________________________
censored |
01-25-2011, 07:56 PM | #2 |
Drives: chevrolet 2010 camaro lt/rs Join Date: Dec 2009
One of the best batteries made is interstate...They are used by construction vehicles and they make batteries for all types of cars.. Remember camaros have batteries in the rear which require a vent tube for fumes.. Interstate has those too. Optima's are gel and semi-gel batteries..They are very expensive.. check out Interstates site..they usually have a warehouse where you can get them cheap..or just buy one wherever you see the interstate sign ...usually at some older pop repair stations. Pay close attention to the CCA and match it appropriately to your car's engine and model
01-25-2011, 08:14 PM | #3 | |
Madman
batt
they aint all that |
01-25-2011, 08:22 PM | #4 |
Drives: All Camaros Join Date: Oct 2008
Optima is made by interstate
68 Camaro RS
87 Camaro IrocZ 98 Camaro SS 10 Camaro SS |
01-25-2011, 08:29 PM | #5 |
Madman
Interesting I wasnt ever aware of that here.. but the reg interstate greenies.. have been a hit or miss.....
everone swears by the optima.. but i guess maybe its a budget vs high end battery.. like: nissan- infiniti.. toyota-lexus..etc |
01-25-2011, 08:34 PM | #6 |
Madman
And actually " they are both made by Johnson Controls." they are not " the same battery./
01-25-2011, 08:41 PM | #7 |
Yes they are made by the same company but are different technology
68 Camaro RS
01-25-2011, 09:35 PM | #8 |
Drives: 2010 Camaro SS Join Date: Aug 2010
Optima Red Top! When it is time for a new battery hands down winner. There expensive but well worth it in the long run. Can handle constant hard draws from amps or just everyday use. AZ is known for being hard on batteries and these things never fail.
Drive it like it was rented and park it like it was stolen!
01-25-2011, 09:43 PM | #9 |
¡ʇuɐıןןıɹq
Drives: 2011 Camaro IOM 2SS/RS Join Date: Dec 2010
I've owned a yellow top myself and can vouch for the quality of the batteries. Well worth the monies. Im looking into getting a lighter battery to replace the stock camaro battery (weighs 45 pounds or so)
01-25-2011, 10:50 PM | #10 |
Drives: C7 / ZL1 / SS / trucsk Join Date: Nov 2009
I just installed the Optima, great...........
2014 C7 Stingray 3LT/Z51
2013 Camaro SS 2012 Camaro ZL1 - 850 HP 2015 GMC Denali 3500HD 4x4 2012 GMC Sierra 3500HD 4x4 |
01-31-2011, 11:23 PM | #11 |
so can anyone give model # for optima battery?
looked in al forum and no one mentions model or part #. thanks for help!
censored |
02-01-2011, 03:15 AM | #12 |
2010 SIM Beige RS 6M
Drives: SIM RS 6M 66 Corvair Silverado LTZ Join Date: Oct 2008
The battery is under warranty......
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America |
02-01-2011, 05:56 AM | #13 |
Drives: 2011 Camaro LS Join Date: Dec 2010
The only issue with a optima is if you dont drive it every day or at least once every couple days a optima is not for you unless you put it on a tender. Optimas dont like sitting for periods of time. They loose charge quickly. I went through 3 of them under warranty on my supra before I found this out. Now I keep a blue top on a tender and its been fine for 2 years now. Go for the yellow top or the blue top if it sits at all and you have a tender.
02-01-2011, 12:06 PM | #14 |
Drives: 2010 Camaro SS Join Date: Oct 2010
Sears Die Hard Platinum is a re-branded Odyssey. I have used these Platinum batteries with good luck in the past. As long as they have one for the Camaro when it dies I'll get that. And it is more continent than some other brands because there is always a Sears around.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
Similar Threads | ||||
Whats the cold Cranking Amps on a 2010 Camaro's battery ? | Jekyll-N-Hyde | 5th Gen Camaro SS LS LT General Discussions | 2 | 01-09-2011 07:59 PM |
Smartest Battery Charger in the World!!! | southerncarparts | Miscellaneous Items | 10 | 02-15-2010 06:08 PM |
Trunk mounted battery replacement | sting808 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 0 | 01-11-2010 05:42 AM |
Smartest Battery Charger in the World!!! | southerncarparts | Audio / Visual / Electronics/ Gauges / Nav | 0 | 12-04-2009 07:35 AM |
GM To Build Battery Plant | Mr. Wyndham | General Automotive + Other Cars Discussion | 5 | 01-13-2009 01:03 PM |
