07-03-2011, 05:23 PM | #1 |
cel code P2177 P2179
I installed a K n N intake pro aircharger 63 series ( plastic black tube). Since my install I had gotten a cel. I have two guys who have intakes check the fittings n all is secure. I also cleaned the air mass flow module and also taken out fuses 5 n 20. I have driven the car the for about four hundred miles and the cel has not gone away. Any advise...?
07-03-2011, 06:07 PM | #2 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Take the K&N off put your stock back on and the CEL's will go away.
For some reason the K & N intake will Set a CEL on some cars. P2177 is system to lean off idle bank 1 P2179 is system to lean off idle bank 2
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
07-03-2011, 09:31 PM | #3 |
07-03-2011, 09:47 PM | #4 |
Then re-install the K n N...? No, the K&N is what is causing the problem trade it for a CAI .
07-04-2011, 08:54 AM | #5 |
07-04-2011, 08:56 AM | #6 |
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602 Join Date: May 2010
Had the same problem, I did reinstall and still got a CEL
07-04-2011, 01:42 PM | #7 |
07-14-2011, 12:22 PM | #8 |
Drives: 2010 SGM 1LT (Manual) Join Date: Sep 2010
I've had the K&N on for over 6 months and now I am getting these codes. :(
2010 SGM Manual Trans
Mods: Flowmaster, Solar Gard Window Tint, Front Bowtie from Gary's Customs, Green LED dome & trunk lights from AAC, Painted calipers used G2 paint, Emblem Pro underhood bowtie, Stealth Bulb turn signals. |
07-14-2011, 03:21 PM | #9 | |
07-15-2011, 09:21 AM | #10 | |
07-15-2011, 09:24 AM | #11 |
Also, you should clean your MAF sensor carefully if you are getting this code.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
Similar Threads | ||||
V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
One possible solution to CEL P0430 w/ JBA midpipes | Goliath | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 01-10-2011 07:55 PM |
Advanced Auto Parts online coupon code | crzycicada | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 0 | 12-17-2010 09:57 AM |
CEL Code after Supercharger Install L99 | DarkNight | Forced Induction - V8 | 9 | 05-06-2010 04:30 PM |
Dealer Installed Options | firehawk1 | 5th Gen Camaro SS LS LT General Discussions | 5 | 04-18-2009 07:17 PM |
