Old 07-21-2011, 01:12 PM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
stock Internals at the track
I have a camaro with close to 600 whp. I love to drag race but I haven't been able to take my car to the track since it was modified. I already have a set of DRs for my car for when ever I get the chance to take my baby to the track. Last night I was talking to a friend about it, and he told me that If the car ever hooked, I was going to blow the internals of the engine. I'm running a safe tune on it with a meth kit as insurance.
What do you guys think? Is there any one with similar HP and stock internals running his car on the track with DRs?
Thanks!!!
Maggie TVS 2300 SC with a 3.6" pulley.
ZR1 Twin Disc clutch.
Hurst Short Shifter.
1 7/8" ARH LT with highflow cats.
Drive Shaft safety loop
Roto-Fab CAI
160º Tstat.
Stage 2 Snow Meth kit safeinjection.
ADM Dual Pump kit
ADM boost and AFR guages
Catch Can.
586 RWHP/ 565 RWTQ
Installed at Lethal Performance San Antonio
www.youtube.com/cgarza12
Carlos Garza is offline   Reply With Quote
Old 07-21-2011, 01:58 PM   #2
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
The engine can handle that and a whole lot more. It all depends on your tune.
My cousin has been running his stock engine(sans cam & springs) with a Maggie on 14 psi and 100 shot(nitrous) without issue for more than a year now. He races it every chance he gets and runs consistent 10.3's.
Again, you can blow the engine with no bolt-ons with a bad tune and it can survive with 800 on a good tune.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 07-21-2011, 04:00 PM   #3
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
I'd worry about the axles, driveshaft and diff before the motor.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 07-21-2011, 04:49 PM   #4
Synner
Drives: cars
Yeah its not the engine that gets shocked its the tranny, driveshaft, diff, and axles. As long as you don't hit valve float or over-rev the engine it'll be fine with a safe tune and meth. Detonation or too much psi will kill the engine not launches.
Old 07-22-2011, 10:48 AM   #5
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
You need new friends... and a better tuner
LC is offline   Reply With Quote
Old 07-22-2011, 01:02 PM   #6
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
If your not getting any detonation, and not revving over the stock 6700... I wouldn't think any immediate motor kaboom is threatening.
With that much power, blower belt load on the cast crank.... it would never pass the OE validation where they full load dyno test it for a few days to simulate 100K + of miles. Long term life expectancy maybe shortened a bit from the big increase in power, But still shouldn't grenade from just a couple passes down the track.
Like earlier mentioned, I'd be more concerned with the rest of the drivetrain on a tacky surface with a slick. I'd keep the launch RPMs reasonable and no speed shifts. Instead of hammering into the throttle at launch and shifts, roll into it quickly. Upgraded trailing arms, toe links, bushings... should help. Will be tough to get a good burnout too if you don't have line lock. Maybe just spin them hard in second in the water and let it roll out of the water spinning fast in second. I've seen many stand on the brakes trying to do a burn out and wind up frying the diff clutches with a one wheel burnout.
Old 07-22-2011, 01:11 PM   #7
Supercharged SS
Drives: 2010 Camaro
Just be sure to fill it with race gas and you should be fine. As always, it's never 100% foolproof but that's about the best precaution you can take. Now hurry up and get to the track. I sent you those dr's almost 18 months ago!!!!
Old 07-22-2011, 11:17 PM   #8
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i have similar, you are good to give it a run,, only problems you may encounter , that is trouble is the dreaded wheel hop. start out with some learning runs to make sure wheel hop is not gonna be a issue...try the 2500 launch with some slip clutch and gas , then early shift 2nd around 5 to 5,500k rpm..i powershift the rest....if you have no problem there you are good to go...tach it up a little more the next ime around...if wheelhop is issue then come back . i am working my wheelhop issues and was gonna run tonight but got rained out...added trl arms..might raise coilovers back up to stock height in rear..for track
mikepage0007 is offline   Reply With Quote
Old 07-23-2011, 02:54 PM   #9
Carlos Garza
Guys, Thanks for the replies. What suspension mods should you do to try to eliminate wheelhop? I was going to modify my cars suspension but, because of work, I haven't been able to do it...
Roto-Fab CAI
160º Tstat.
ADM Dual Pump kit
Catch Can.
586 RWHP/ 565 RWTQ
Old 07-23-2011, 10:45 PM   #10
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
I run similar hp and torque as you. I run DR's and have about 60 passes this season alone on the car. Well over 100 passes total with the stock bottom end. I believe your weak link will be an axle. I put in DSS 1400 hp axles. I do however, plan to stroke and forge the motor this winter.
For wheel hop issues, a good start would be diff bushings, solid sub frame bushings and trailing arms. Pfadt suspension products are my preference.
Go to the track and have fun.
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 07-24-2011, 12:01 AM   #11
mikepage0007
Drives: 2010 camaro
if you can,t do everything ..get the trl arms 1st, and dropped camaros, have more tendency to hop..drop some air pressure in rear to soften sidewall a little
Old 07-24-2011, 07:20 AM   #12
newmoon
newmoon's Avatar
Drives: 2013 Boss 302 RR
Did anyone else catch this month's issue of Hot Rod where they have pushed a junkyard 5.3 liter LS motor with nothing more than opening up the upper ring gap to over 1200hp with a pair of turbos, pretty impressive!
2013 Boss Mustang - Present Toy
2012 SRT Challenger 392 auto 12:40s 112 stock
2012 Ford Mustang 5.0. Brembo, 3:73s
2010 SS, LS3, Cammed, LTs, 12:20s
2004 Redfire Cobra, Pullied & Tuned
1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot
newmoon is offline   Reply With Quote
Old 07-28-2011, 02:19 PM   #13
JM10
Se habla español
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Where does your cousin run?
Been hearing stories about some sick camaros running low 10s with procharger and nitrous with stock engines.
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
What if you brake your stock car at the track? Bad70supreme Dragstrip and Launch Techniques Discussion 23 04-01-2011 10:15 AM
H-Team Track Day at the Streets of Willow Hotchkis Camaro Motorsports Discussions 1 03-25-2011 02:45 PM
Track times Stock to Upgrades??? LDHitman23 USA - Southcentral 7 11-12-2010 01:22 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
