02-17-2014, 06:30 PM | #1 |
Installed intake and...
What's up gents!?
Finally got my Halltech intake, and it's pretty sweet. In the pics you'll see the lining is too short, but Jim said he'd send me proper length.. However, I was curious, when you guys installed your intakes, does is Rev faster than normal in gears? It felt like i could go longer in first before, and now it just revs so fast, I have to switch to second pretty quick. Gas mileage went down a tad, but nothing too bad. I used to feel really fast in 3rd, and now it kinda feels mellowed out. You think it's just me? I can feel it breath easier, obviously... and yeah it feels faster. what do you think? I'm still giving it time to re-learn (installed on Friday) Does the middle hole where the tube goes through need another liner? (for those who have the Halltech) |
02-17-2014, 07:51 PM | #2 |
old school chevy rodder
I know you may like it.... But that kind of looks cheap, there no seal where the tube goes in the box, no insulation, and the tube looks plastic...and it is... And no mine is a CAI intake it did not rev fast in gears, it has a additional scoop to help make a better path for the air to come into the box , not just the same gap as stock with the 1" around the firewall, also a relocate for the windshield wiper fluid filler and tank. I did notice it had a nicer sound to the engine, Just hope you do not have to spray oil on that filter like a K&N. And maybe that seal is supposed to go around the tube you just have stuck in the hole that should have a seal around it!!!!!
My tube is ceramic coated metal BTW and keeps IAT's down
02-17-2014, 09:17 PM | #3 |
I know what you're saying, and you're right. At the moment it looks cheapish...
Again, it's missing those linings and I've talked to Jim and he said he will ship out the missing linings. He agreed the original (on top) was too short.. He's fixing that. Other than that, it seems to do better than stock. once I get those linings, I should be ok. The Halltech Yellow Jacket is actually a good intake to get, as well as the CAI - I just didn't like the look. I saw it in person.. to each his own. |
02-17-2014, 09:19 PM | #4 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
You bought the wrong "ceramic coated metal intake" that keeps IAT's up. You spread a lot of internet myths and bad info sir.
02-17-2014, 09:20 PM | #5 | |
V8 Lounge member #2
Listen to noob, please excuse him.
02-18-2014, 12:55 AM | #6 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
His shield is missing some of the seals, as he explained. Jim is taking care of that. That intake isn't plastic, it's composite. It keeps the IAT's down as well. It also has the biggest velocity stack you can get on a Camaro intake. Did Jim paint the "Haltech" raised letters, or did you?
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
02-18-2014, 01:12 AM | #7 |
I painted it with a paint marker.. Was originally going to do my stitching on the dash, but the color looked more pink than anything.
So I tried on the intake |
02-18-2014, 05:43 AM | #8 |
Search Ninja
I was wondering if Jim decided to start doing that. I along with a few others did it to ours several years back. I made the suggestion to him so that's why I wondered. Glad you like it. Sucks that it got out without all the seals but Jim will make it 100% right. You made a great choice for your CAI.
02-18-2014, 07:08 AM | #9 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
There needs to be a seal around the tube where it enters the box. Looks as though the tube may be too long. The Halltech logo is half in and out of the box. Quite possibly not allowing the filter to slide on the tube far enough and to act as the seal into the box. My thoughts would be to pull the tube out, push the filter's rubber boot through the airbox opening. Lay the tube over top the airbox/filter to verify the tube is not too long and would not contact the filter media. If tube is correct length, insert tube into the filter and then at the throttle body. Tighten hose clamps at throttle body and then inside the airbox at the filter.
Imo, something doesn't appear correct. Why have the name positioned on the tube so that it is separated by the box. Also, if you are able to push the filter on the tube further, it will partially cover up the name. ??? Thinking wrong tube. ??? Maybe the tube just needs positioned better as well. Idk. Not to jack, but the metal/non metal tube could be debated. If hp gains are made with the intake you have and your happy with it, that's what matters.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
02-18-2014, 08:02 AM | #10 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Dude that looks wrong to me, my rotofab has a full liner and the plastic connection pipe that goes through the box is secured against the box with several screws and its angled to clear the wheel well. Put your stock filter back on and see if there is a major change it only takes a few minutes. loss of power seems odd.
02-18-2014, 08:16 AM | #11 | |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
This is how my Halltech looked when I had one back in the day.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
02-18-2014, 09:39 AM | #12 |
GrINned & JUICEd
Had a fairly large bow in the airbox side where the tube enters. Was that the filter supplied by Halltech? Seemed too long. Unless the boot on the filter could have fit into the airbox tube area. How was that area sealed when you had the Halltech? Appears the rubber boot on the filter was pressing on the side of the box.
02-18-2014, 09:57 AM | #13 | |
02-18-2014, 10:48 AM | #14 |
GrINned & JUICEd
QUOTE=bhillakaiceberg;7430482]Yea man, hence why I "used" to have it. Well, I bought it off a forum member, so I really don't know if it came from Halltech like that or not. However, it seemed brand new. I used it for about 6 mths. The area was sealed pretty good with the rubber on the top of the frame.[/QUOTE]
Only found a pic from Halltech, no instructions, looks like you had to do what you did in order to seal off the tube/tube hole. Appears the way it seals is having the velocity stack on the end of the tube press against the inside of the airbox. Thus the reason for the bow. http://www.camaro5.com/forums/showthread.php?t=55108 Or maybe the velocity ring separates from the tube and then you sandwich the airbox side between the two.
