#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 05-27-2018, 09:34 PM   #1
TenSeven
Drives: 2016 Camaro SS
Painting Calipers - Be Aware Of This
I apologize in advance if this is common knowledge or has been discussed before, but I didn't know.
This weekend I painted my brake calipers Garnet Red using a kit from G2:
Yep, it doesn't match. In the can the paint looked to be a spot-on match, but as I was applying it I thought it looked too dark. Then I thought it would lighten up after more coats were applied. Then I thought it would lighten up as it dried.
It didn't.
What I believe happened is Garnet Red is not a "solid" color, it is translucent (I think that's the right word) which means it is sensitive to what color it is be applied to. Since my car's calipers are very dark grey in stock form, the GR paint picked up the very dark base color, causing it to be darker in appearance.
Solution: Paint the calipers with an appropriate silver base coat before applying the Garnet Red.
I tested this solution by painting a strip of plastic half very dark gray, and half silver. I then painted the entire strip of plastic Garnet Red using paint from a DupliColor touch-up kit.
The result of the test was the strip of plastic had 2 different shades of red, exactly like the above pics.
I'm trying to decide if I'm going to just leave them as they are or if metallic black calipers are in my future...
TenSeven is offline   Reply With Quote
Old 05-28-2018, 05:42 AM   #2
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
I would leave them as is. I personally think that calipers matching the car's color are not as good looking as a set that doesn't match.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 05-28-2018, 06:26 AM   #3
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Hi, just out of curiosity did you have to remove the calipers when painting? Thank you!
T
2012 Victory Red ZL1
Lingenfelter 630 Package "Plus"
592 HP/580 TQ
BoostedX2 is offline   Reply With Quote
Old 05-28-2018, 03:25 PM   #4
TenSeven
I'm probably going to leave them as they are for now and see how I feel about them later.
T
While I did remove the calipers to install the new rotors, I bolted them back on to paint them. Having them bolted in place made them much stable for brush painting. If they were being spray painted, I probably would have left them off the car.
Also, don't use the brush G2 includes in their kits as it is not the best quality. Go to a craft store or home center and get a 1" foam brush and a couple of small regular brushes. They will do the job much better.
Old 05-28-2018, 08:43 PM   #5
parbreak
Drives: 2017 50th Camaro SS
If those are PowerStop rotors, be aware the hubs will probably rust as they are not zinc coated. Ask me how I know. I'll be pulling mine soon to paint the hubs.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 07-10-2019, 04:51 PM   #6
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
I realize this is an old thread, but I had the same thing happen to mine two days ago.
The color match was way off and I had to put at least 4 coats of the paint on to cover the silver lettering on the calipers.
Also, very disappointed that the paint did not flow level. You can see all the paint brush strokes, not smooth at all.
Followed all the instructions to the tee. Even the advice to get a different brush.
Oh well, I'll leave it like this till winter and pull them off and have them powder coated.
overdriv is offline   Reply With Quote
Old 07-17-2019, 09:50 AM   #7
BOYD3800SII
Drives: 2017 RS CAMARO V6
Same thing happened to me! Wish I had used the black kit instead of the blue kit. Mine came out very light powder blue in the light even with multiple coats with the G2 kit. I had to get buy a can of VHT caliper blue and sprayed over it to correct the color difference.
BOYD3800SII is offline   Reply With Quote
