08-07-2019, 10:10 PM | #1 |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
Front license bracket, it's not that bad
Unfortunately, I live in a state where they love to give you tickets for no front plate, so I was mulling over: do i risk it or how bad is that OEM bracket to install on the car? Can I change my mind after?
Looking online, not surprisingly, everyone is trying everything but the stock bracket, and no info about the 2019s. The main objection I noted (with the 16-18s) was drilling holes in the front bumper. No way I'm drilling, so what are the options? That don't cost anything? The answer, check the fit of the OEM, then decide on spending money. As a veteran of GM instructions sheets, the one in the bag with the bracket was this side of hieroglyphs, so it's: what's this part do? time. Praise insightful engineers, no drilling. For the SS/1LE folks, no drilling. Everyone else, sorry. Insert the nut clips into the anchors, match the RH & LH pieces on their respective sides, turn the "feet" sideways through the grill holes then vertical again on the backside and tighten the screws, and this thing mounts anchoring to the lower grill, nice and neat, and best of all, can be removed in one minute if needed. Hope this helps someone with the same problem of whether to use the stock bracket or not. Tip of the hat Camaro Team, this is painless and still optional.
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51 Ordered 2024 Radiant Red 2SS 1LE Ordered: 6/15/23 Accepted: 7/5/23 3000 - 7/5 ---> 3100 - 7/19 3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7 4300 - 8/14 --->4B00 - 9/5 DELIVERED 9/20!! |
08-08-2019, 06:16 AM | #2 |
Drives: 18 1SS/1LE Join Date: Jun 2018
Nice to see the 19 isn't pop riveted on there like the 18. I chose to just put it on, in my area they enforce that pretty hard and this time I just chose to not endure the hassle of being stopped and reprimanded for no front plate. Never got a ticket but I don't need the man in my life over a plate.
08-08-2019, 06:23 AM | #3 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-08-2019, 08:39 AM | #4 |
Drives: 2021 Acura RDX SH-AWD Advance Join Date: Aug 2019
I wasn't going to put mine on either if I had to drill holes. I was pleasantly surprised when I discovered that it just clamps on. The law is due to change in Ohio on 7/1/2020 allowing no front plate but now there's legislation to try and keep the front plates on. Either way, I'm good with this set-up. Nice job, Chevy/GM!
08-08-2019, 12:32 PM | #5 |
Drives: 2016 1ss camaro Join Date: Feb 2016
lol eww i used the zl1 addons tow hook one at least its removable and no holes or clips on car
08-17-2019, 02:56 PM | #6 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Best thing is...no drilling!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
08-20-2019, 06:55 PM | #7 | |
Old school tech
08-31-2020, 11:09 PM | #8 | |
Drives: '19 Camaro M1SS1LE Join Date: Aug 2020
09-01-2020, 11:02 AM | #9 |
Called the dealer, the GM part number is 84618405. Kit comes with mounting brackets and hardware. GM 84618405 is the same part pictured in GM-ACEs pictured post. It costs about $42 from the dealer.
09-01-2020, 05:06 PM | #10 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
I got the stock GM one for my 17 RS. I did not drill holes. There are 2 clips that snap on the grill, with the intention that the rivets will hold the top of the bracket to the painted surface of the bumper. By lowering the mounting position, (and trimming a bit of the clips to fit) I was able to get the clips to secure to a lower part of the grill, and I used wire ties to secure the top of the bracket to the grill. It's stayed in place for over 2 years no problem.
09-03-2020, 12:34 PM | #11 |
Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
my dealership actually provided me for free the tow hook license brake bracket to mount my front plate. pretty cool they only offer it on the camaro or corvette
10-06-2021, 08:32 PM | #12 |
Drives: 2021 Camaro 1SS Shock Vert Join Date: May 2021
I just put my OEM one on my 21SS. No drilling and a 10 minute total install. Nice job GM. Reminded me of the old Fiero front plate bracket.
10-08-2021, 12:50 AM | #13 |
Drives: 2016 camaro Join Date: Mar 2018
Mine just arrived today. Will mount it this weekend.
04-07-2022, 06:51 PM | #14 |
Drives: 2022 1SS 1LE Join Date: Nov 2021
Old thread but good info. Just got my plates today and installed this. Instructions are bad, but this thread made it a breeze. Thanks. Looks good too.
2022 Shadow Gray Metallic 1SS 1LE A10 Rotofab Dry ST delete.
Tags |
license plate bracket, oem |
