11-20-2017, 10:17 PM | #1 |
Drives: 2016 Camaro 1SS (Dory) Join Date: Jun 2017
Won't accelerate and oil pressure up as accelerating
So I have a 2016 SS A8.
I installed Bullet Performance cat delete pipes with Bid Daddy Garage anti cel sensors and everything sounds good. The problem is when I got on the freeway to accelerate quickly. The car didn't want to move, almost as if it dropped the power of the engine. It would still go but very slowly. I also noticed harder shifts. On top of that the oil pressure guage shows the oil pressure going up as I accelerate. What could be the issue? Is it just in need of a tune? I did research and thought I didn't need a tune with cat delete. Any help would be great. Edit: so woke up today and two check engine lights. P0135 and P0051 Last edited by J_mo30; 11-21-2017 at 08:47 PM. |
11-21-2017, 09:24 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Oil pressure goes up with RPM, not a surprise there.
The first step is to undo whatever you touched. If the problem doesn't go away, then it's something else, or you induced a bigger issue. Hopefully those "anti cel sensors" didn't fry your ECM.
2017 "M1SS1LE" in Hyper Blue w/PDR
11-22-2017, 09:08 AM | #3 |
Drives: 2016 Camaro 2SS NGM Join Date: Jun 2014
Lmao , and y3s bid daddy garage sounds shady, I have the efi tuning cel deletes and i have never had any problems
11-23-2017, 11:28 PM | #4 |
Drives: SS Join Date: Jan 2017
Are these primary cat deletes or secondary cats?
11-24-2017, 10:41 PM | #5 |
It's primary cat delete. I used the anti CEL adapters and I even switched out my O2 sensor today to see what would happen and still does not run good.
The engine is misfiring. I'm getting more codes now. P3403, P3427, P3443, P3451 |
11-25-2017, 09:54 PM | #6 | |
Banned
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
Why the name "Big Daddies Garage" ? The owners last name is Daddies, he's 6' 4" 275 lbs, hardly no body fat. LOL http://www.bigdaddiesgarage.com/faq....ddies%20Garage |
11-26-2017, 12:32 PM | #7 | |
Drives: 2017 Grand Sport Join Date: Oct 2013
Those codes tell me there is something going on with your DoD cylinder deactivation. Signal low on multiple cylinders. Doublecheck all wiring in the area that you did work, and make sure there are no burned wires. |
11-26-2017, 12:48 PM | #8 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
11-26-2017, 06:15 PM | #9 |
a simple cat delete will not require a tune for the car to operate properly. The purpose of the tune would be to disable the rear o2 sensor codes to prevent a check engine light from coming on.
11-26-2017, 06:20 PM | #10 |
11-27-2017, 04:02 PM | #11 |
Well I put the cats back on and still running terrible.
Took it to the dealer and awaiting a diagnosis. |
11-27-2017, 11:34 PM | #12 |
11-29-2017, 08:34 AM | #13 |
Well got the car back and it was simply an O2 sensor fuse. The fuse blew and that's why there was no/low power to the O2 sensors. Since they weren't reading properly it caused it to dump more fuel than needed into the engine. In return the ECM started shutting down cylinders to protect the engine. So a simple fuse caused it all.
11-29-2017, 10:58 PM | #14 | |
