#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > I4 Turbo LTG Engine, Exhaust, and Bolt-Ons
Old 02-11-2022, 09:44 AM   #1
Davescamaro
Drives: Chevy camaro
Clutch/flywheel?
Hey all,
Needing some input on which kit to get. Based upon my setup, I'm torn on which setup to go with. Trying for something that can hold torque, but have lifespan of close to oem and feel. I've seen clutchmasters, but they rattle or spec clutch.
Any help would be great!
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 02-11-2022, 10:02 AM   #2
ctrlz
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP
No experience with this beyond drooling at the pictures:
https://www.camaro6.com/forums/showthread.php?t=600641
ctrlz is offline   Reply With Quote
Old 02-11-2022, 06:44 PM   #3
MSU120
Drives: 2018 1SS 1LE
I’m partial to this one too
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 02-14-2022, 11:46 AM   #4
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
That is obviously not compatible with our manual transmission. Go with Spec. They are the best option.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 02-14-2022, 01:03 PM   #5
Davescamaro
So probably the stage 2 option? I will get their flywheel as well to reduce Rev hang and quicker revs.
Old 02-15-2022, 01:12 PM   #6
ctrlz
Well, there you go.
So much for looking at pictures.
Old 02-18-2022, 06:31 PM   #7
Start The Machine
You have to get their flywheel with it. Their clutch is not compatible with anything else.
Old 05-09-2023, 07:18 PM   #8
427
Drives: Camaro
My engine is out for piston/rod upgrade and my factory clutch is also damaged. What did you end up with, and did you like it?
Kurt
427 is offline   Reply With Quote
Old 05-18-2023, 04:24 PM   #9
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
What clutch did you guys go with?
We are big fans of the Spec clutches. These are great quality clutches and even as you hit stage 3 remain comfortable for daily driving.
Sales@Phastek is offline   Reply With Quote
Old 05-18-2023, 10:41 PM   #10
Davescamaro
I have not gotten a clutch as of yet. Getting suspension parts atm. I was leaning towards the stage 2+ and flywheel for end of summer time.
Old 06-24-2023, 11:57 AM   #11
427
Drives: Camaro
I haven't been on this sight in a minute, thanks for the reply. My flywheel had already moved, I think I want a solid flywheel this time when I replace the clutch. My clutch still seemed like it functioned well when I took it apart, but I don't drag race it or run it hard anywhere with much tire grip. I run it in an open road race here in Texas, and my son sometimes uses it for autocross. He takes off aggressive at the autocross, but grip isn't very good so I'm not sure it's very hard on the clutch. I was surprised that the factory flywheel was already twisting out of place, and it's very heavy! What brands offer a kit with flywheel included that will hold 400-450hp?
Kurt
Old 06-28-2023, 11:42 AM   #12
Davescamaro
I think clutchmasters and spec are the only 2 that offer a flywheel to be used with their clutch. I have not seen any of them put out torque capacity, but I would imagine the spec 2 clutch and clutchmasters 400 would do well for the above 400 torque curve.
