Old 12-28-2018, 03:31 PM   #1
205
Drives: 2010 Camaro
Best way to remove hood?
Should I take the hood from the hinges? Or, take the hinges from the body? Just looking for the best way to be able to line the hood back up easily. Thanks
205 is offline   Reply With Quote
Old 12-28-2018, 03:35 PM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
I've never taken the hood off my Camaro, but every other vehicle I take the hood off the hinges.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 12-28-2018, 03:42 PM   #3
Codiath
brakes for squirrels
Codiath's Avatar
Drives: 2012 45th Anniversary 2SS
+1 to hood off the hinges, some witness marks might help when starting to realign everything.
Codiath is offline   Reply With Quote
Old 12-28-2018, 04:43 PM   #4
HDRDTD
One trick some car builders do that will insure the hood gets put back with the same alignment as before is to drill a single hole thru the hood and hinge (usually a 1/8" hole) on each side, then go ahead and unbolt the hood from the hinges.
When it comes time to reattach the hood, line it up and bolt it loosely, then take the same drill bit you used to drill the small holes, and insert it right back in the hole that you drill thru both the hood and the hinge. It will act as an alignment pin. Repeat for both sides of the hood and it should line up perfectly,
Old 12-28-2018, 07:42 PM   #5
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
I've removed my hood twice, removing the hood from the hinges is 100% the way to go.
Talladega is offline   Reply With Quote
Old 12-28-2018, 08:36 PM   #6
205
Drives: 2010 Camaro
I just removed it from the hinges. I tried to tape around the hinge to mark it. We will see...
