03-27-2021, 04:49 AM | #1 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Opinion on Portable Lifts
Hello, I was thinking about purchasing one of these and was wondering any opinions on ones you might have. I've been looking at this:https://www.northerntool.com/shop/to...0900690a240612. Thanks!
03-27-2021, 06:31 AM | #2 |
I have the BL-7000SLX and like it a lot. For me, my car is lowered so I also use a set of Race Ramps that are 3" tall for a little extra room to add taller blocks to the quick lift. Takes a few minutes to get set up before lifting the car but not bad. Might check out Costco as they are quite a bit less there. Home Depot also has them and runs sales every so often.
Here are a few threads - https://www.camaro5.com/forums/showt...ght=quick+jack https://www.camaro5.com/forums/showt...ght=quick+jack
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-27-2021, 09:35 AM | #3 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
I keep considering a Quick Jack but I always talk myself out of it. My concerns are ingress and egress when working under the car (transmission work etc), trusting my life to Chinese made lifting equipment, and if it takes a bit to set up (as stated above) I may as well crawl around on the ground with my current jack/stand ensemble and save $1500. I also have considered the MaxJax assembly from Bendpak. My hesitation is again shelling out big bucks for lifting equipment with quality on par with Harbor Freight but unfortunately the choices are minimal.
03-27-2021, 10:15 AM | #4 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-27-2021, 10:16 AM | #5 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I was thinking about getting a lift, and something portable, but I opted out. I couldn’t justify the cost since I don’t do that much work on the car unless it’s an oil change. Even with oil changes, I get the car up pretty quick with a low profile jack. I would put in a 2 post lift if I run out of room for my cars/toys. For now I still have space. :/
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-27-2021, 10:30 AM | #6 |
Drives: 2013 2SS Join Date: Mar 2014
I've been considering one of these but for not much more I am leaning towards a 2-post lift.
03-27-2021, 10:44 AM | #7 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I have a BL-5000EXT on order. Not buying it for repair/maintenance work as much as convenience when it comes to changing tires/wheels for cleaning, and for ease in waxing/polishing the doors and rocker panels.
The older you get, the less fun it is to bend over for any amount of time. In other words, I'm lazy. I have a 2013 ZL1, and when I measured the distance between the factory lift points as recommended by QuickJack, I saw that with the SLX, I'd be about an inch shy of the optimum reach, so I decided to just go for the EXT version to play it safe. QuickJack tells me my BL-5000EXT frame is currently in production and should ship in two weeks or so. |
03-27-2021, 07:49 PM | #8 | |
03-27-2021, 07:59 PM | #9 |
Drives: Camaro 1LE Join Date: May 2018
I bought a 5000 ext after I bought my 1LE a couple years back. Been more than impressed with it and feel completely safe while under the car. Definitely no china junk from what I have seen of mine.
03-27-2021, 09:12 PM | #10 |
Big John
Drives: Wife 2013 Camaro 2SSRS / ME? Join Date: Mar 2012
I've been looking at this one for the last year or so.
Think I'm going to pull the trigger this summer as the wife's Iroc will be coming back from the paint shop and will be doing engine, transmission, and rearend. https://www.twinbusch.com/product_in...products_id=24 |
03-27-2021, 10:02 PM | #11 | |
03-28-2021, 02:33 AM | #12 |
Thanks for the opinions!!! Now a couple thousand roses to the wife should do the trick. Wait, maybe 2 thousand because she did pull the large ribbon trick on me at the dealer when "we" bought it. I had no idea either. What a great day that was . Great wife too(and she's not even glaring behind me as I type this).
03-28-2021, 09:45 AM | #13 |
Drives: 2014 camaro SS Join Date: Jan 2019
I built a set of ramps 4' long and 8" high that meet up with platforms. the ramps are removed leaving clear space. jack up the rear and put on stands or platforms under the tires and you are set for working under the car. made everything with 1 sheet of 3/4 plywood and good engineering.
04-02-2021, 06:50 PM | #14 |
Banned
Drives: zl1 blk Join Date: Nov 2017
i bought a set for 1k... off fb market place.. never unboxed.. i have a new backyard shop and near future plans on a full sized lift .. but in the meantime i felt safer with the quickjacks than four jackstands... easy to use .. did a driveshaft change . trans cooler install .. and now doing a paint correction .. these are prime units for intense paint care.. or doing brakes. cons are u can only slide in from the back or front of the car..also take up space while not in use. i just slide em under one of my other projects.
