07-29-2024, 01:20 PM | #1 |
Remote Tuning
I need some minor remote tuning done to account for my 169* thermostat.
I got a remote tuner from RPD Store years ago that came with "Free remote tunes for life", but with RPD Store gone and dynosteve's inbox is "too full to receive messages", I don't think that claim will be honored. I need an alternative. Thanks for the help!
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
07-29-2024, 01:26 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I would just find a local tuner to make the changes. Basically, all it is are changes to the fan settings.
Although there is a lot of pushback on HP Tuners forum by the most experienced tuners to not go anything like that low on the thermostat. If I'm ever back into mine again, I'll probably bump mine back up to stock and leave the fan settings a little more aggressive. |
07-29-2024, 09:11 PM | #3 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
You can Contact Steve here, Not sure if he will honor the Tunes for life though RDP.
https://www.dspperformancemotorsports.com/
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-30-2024, 12:03 AM | #4 | ||
However, I was also told by a mechanic who builds endurance race cars for the Lucky Dog race series that the engine "optimal temperature" needs to be changed as well. He mentioned if the ECU is set to recognize 187* as optimal operation temp, the ECU will put the engine in a "warm up" mode, which is not as efficient, until the temp has reached the programmed value. If the thermostat is changed to a lower temp one, the ECU will stay in that mode because the temp is not reaching the programmed "optimal" temp. Not sure if that is true for our cars tho. This mechanic specialized in BMWs and Audis... Quote:
2013 1SS/1LE
07-30-2024, 07:39 AM | #5 |
You are probably correct, there will be at least some DTC changes to make. But my point really was that this won't need "tuning" of drive cycles, log reviews and multiple changes. It should be a one and done type of change.
07-30-2024, 07:44 AM | #6 | |
GPI Sales Consultant
If you have an HPTuners MPVI module, and not the RTD module, then it would not be super complicated to make the required changes yourself. I'd be happy to share some screenshots from HPTuners for the fan tuning settings I have used with lower temp thermostats. If you do have an RTD module, those can only be used to write tunes prepared by tuners that use those devices. If you're looking for a remote tuning resource then you might consider us here at GPI. While your fan tuning needs are very simple compared to the initial cost of remote tuning, if you're planning future modifications we could be a great resource to help you thought those changes as they come. If you've got questions, feel free to reach out directly to andrew@gwatneyperformance.com
Got a question about a GPI product? Feel free to shoot me a message! |
07-30-2024, 11:57 AM | #7 | |
Thank you very much for straightening out that for me. I didn't think our cars had a "warm up mode", but I didn't know that for sure. The kind of tuner I have is the RTD style hand-held. From what you have told me, the fans being programmed to switch on earlier is not essential. My hood is heavily ventilated with vents from TrackSpec. It holds around 180-185* just through natural convection. It only goes above that when driven hard or hot days. There are no plans currently for anything big enough for some fresh tuning. I need to get her back out on track more since my latest mods to see what she needs next. I'm leaning at getting the intake done with the GPI Ported and Rod Mod done up probably next year.
2013 1SS/1LE
07-30-2024, 01:46 PM | #8 | |
I agree that you're fine without any changes. One thing you might consider is using a fan switch to manually control the fans when you want to apply some focused cooling. I have had the PCM of NC switch in my car for nearly a decade, and while I use it sparingly, it is a very nice tool to have at the drag strip or circuit course when I want to really force as much cooling as possible. It also has the benefit of being far cheaper than any of your remote tuning options, and will give you total control. https://www.pcmofnc.com/product/2010...tch-harness-3/ I also have a how-to for manually over-riding the fans to permanently be on low. You can find that here: https://www.camaro5.com/forums/showt...oogle_vignette
07-30-2024, 02:10 PM | #9 |
I have one of the PCM of NC fan switches also. I use it to reduce the IAT2 temperature after the intercooler has heat soaked while parked.
07-31-2024, 08:26 AM | #10 |
https://mailordertuner.com/
Run by the guy that does the Texas Speed Performance tuning. This will be my tuner soon.
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
08-13-2024, 08:58 AM | #11 |
Ted Jannetty of Janetty remote tuned my SC 2010 SS. The other guy that used to be on the Web just took my $1K and bailed. Ted is a seasoned Pro, and has a extensive Tuning process that provides killer results.
Thread Tools | |
