Old 08-10-2024, 02:01 PM   #1
ccutaia
ccutaia's Avatar
Drives: 2012 Black 2SS,
Limits of a stock manual drivetrain????
Hi, I have a 2012 SS with 680 HP to the rear wheels, 6-speed manual, GM 1LE 391 rear-end gears, and stock-size Mickey Thompson drag radials. Can the car handle coming out of the hole using its Launch Control without breaking?????
ccutaia is online now   Reply With Quote
Old 08-10-2024, 02:30 PM   #2
Leo72793
Drives: 2011 2SS/RS
I wouldnt recommend a straight dump with 0 suspension supporting mods. Axles wont like it, nor will most of the rear suspension. Trailing arms, toe arms, bushings all should be considered to prevent hop, rear suspension flex and help the axles handle it.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 08-11-2024, 04:51 AM   #3
bsn
Drives: 2013 ZL1
Traction and wheel hop are what kills a manual driveline. If you still have the stock suspension your probably going to break something at that power level with drag radials.
bsn is offline   Reply With Quote
Old 08-12-2024, 08:10 PM   #4
fz4k98
Drives: 2013 1ss
I put a whipple on mine (610rwhp) and all was fine on stock drivetrain until i put slicks on and went to strip. When the weak spot is traction, all is fine. When you eliminate traction as weak spot it will find the next and break it, and the next, and the next. But it sure is fun.
fz4k98 is offline   Reply With Quote
Old 08-13-2024, 10:09 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
At 700whp and 10" slicks, I've broken a ZL1 axle and a one-piece driveshaft on the two-step at 14 degrees of retard. I upgraded the axles to Gforce Outlaws before the one-piece drive shaft broke and then returned to the stock driveshaft. Now at almost 800whp on E85 and going to track Saturday, so we will see how the stock shaft holds up.
Edit: no driveline issues, but I could not get the car to build a lot of boost at the line.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
