07-18-2021, 10:30 PM | #1 |
Drives: 2010 Camaro 2SS RS Join Date: Jul 2021
5th gen Camaro OIL PUMP
Okay doing a lot of work here and want to sum up some information.
I will post a link to the video in this thread. Does this look like a properly installed oil pump? I’m going to run this melling oil pump and I seem to see a small hair line crack with the mating surface of the pump and pick up tube? Is this okay? Or am I In trouble? Link to video: https://m.youtube.com/shorts/TKi8J5RRK-g?feature=share |
07-18-2021, 10:44 PM | #2 |
Hard to see the crack in the video. I think it's fine. How would it get cracked?
Last thing you want is aeration in the oil, froth. I took out my oil pump last summer so I'm familiar with the setup. Was your pressure around 30 psi at idle before you started the tear down?
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
07-18-2021, 11:42 PM | #3 | |
07-19-2021, 12:45 AM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I could see it. And I don't know if I would chance it or not. If it was up to me I would get a new pump just to be safe.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
07-19-2021, 01:46 AM | #5 |
So after chatting with a buddy of mine that works for Chevy... Turns out it’s pretty normal, he did explain with higher pressure I could add a brace as added protection. He explained summit racing sales them? Any idea what it’s named/branded as? Thank everyone.
07-19-2021, 09:59 AM | #6 |
Here's a couple.
https://www.amazon.com/Pump-Girdle-P...a-819528924375 https://www.ebay.com/itm/16395255490...4aAn4sEALw_wcB
07-19-2021, 09:59 AM | #7 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
That’s perfectly normal in my opinion.
07-19-2021, 10:35 AM | #8 |
I've went through 1 stock oil pump 3 melling oil pumps so far. And not one of them had a crack. If it did I would have sent that damn thing back and got a new one. To each his own.
07-19-2021, 12:35 PM | #9 |
It’s not a defect, the melling pump is perfectly fine. The issue is more so with the pick up tube flange mounting to the surface of the melling oil pump. There is a very very small (finger nail width) gap between the pick up flange and the oil pump. From what I understand it’s normal and it’s perfectly fine. However they sale braces to fix the issue. It’s so small you barely notice it any. The seal is perfectly fine. The flange kinda offsets since there is only a bolt on once side. No biggie.
07-19-2021, 12:42 PM | #10 |
Oh ok. I thought you were referring to an actual crack in the pump housing. Then yes a brace would definitely fix that like one of the ones I posted earlier. I didn't need one because when I take my pumps off I have the oil pan off so I can actually get the second bolt on the pick up tube.
07-19-2021, 01:17 PM | #11 |
Drives: 2015 2SS/RS 1LE Join Date: Nov 2020
I did not like the fingernail-ish sized gap on mine so I took the gears out of the pump and was able to get the pickup tube completely flush from the inside. They don’t fit together perfectly, especially with the pickup tube mounted already. Worked for me
SE 1 7/8 tubes and 3 inch X pipe, Vararam DRX, TSP stage 2 cam, Deatschwerks 50 lb injectors, Motion catch can, E85. More to come.
07-19-2021, 02:42 PM | #12 |
I have one of the oil pump pickup tube 'girdles', or brackets. Works well and helps to put a more even pressure on the pickup tube mounting surface. I'm not sure why GM has 2 threaded bolt holes in the OEM pumps but only used a pickup tube with one bolt provision.
Getting a good seal from the pickup tube O-Ring is crucial, so hopefully this will help you.
07-19-2021, 02:52 PM | #13 | |
07-19-2021, 04:37 PM | #14 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
If the pick up tube flange and the oil pump are not totally flat to each other start over. Don't force it you could nick the o ring and suck air. The threaded boss for the secondary brace is to the left and higher up. Easy to put on
