Old 09-15-2016, 12:27 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
19" Wheel Options
Thinking about dropping down to 19 inch wheels for autocross. Forgelines are out of my budget so what are going to be my next best options?
Sent from my SM-G920V using Tapatalk
Retro69 is offline   Reply With Quote
Old 09-17-2016, 07:07 AM   #2
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
I'm looking at a nice closeout price on winter tires but I also need a 19"x9.5" or 19"x10" wheel. Sourcing these are tough!
terry_b is offline   Reply With Quote
Old 09-17-2016, 10:44 AM   #3
15cammedSS
15cammedSS's Avatar
Drives: 2015 2SS....white
Subscribed
2015 Summit White 2SS/RS with NPP.... Roto-Fab intake....Phastek lowering springs....BMR strut brace....custom cut blower cam and tune by Matt Sorian.....@MSTuning...BTR valve train....stainless power longtubes with HF cats....Phastek supplied
15cammedSS is offline   Reply With Quote
Old 09-18-2016, 10:01 AM   #4
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
I'm looking for 19" too
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 09-18-2016, 11:39 AM   #5
Wacko37
Wacko37's Avatar
Drives: 2010 2SS/RS & 2007 2500HD D-Max
all depends on your budget. if you want at least rotary forged, the lowest I found was $1600
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, 1LE struts w/Z28 springs, JPSS Camber plates, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast
Wacko37 is offline   Reply With Quote
Old 09-18-2016, 12:24 PM   #6
Retro69
Retro69's Avatar
What brands were you looking at?
Old 09-18-2016, 01:01 PM   #7
Wacko37
Wacko37's Avatar
apex ARC-8
Old 09-19-2016, 02:02 PM   #8
Need4speed_motorsports
Need4speed_motorsports's Avatar
Drives: 2016 Camaro SS
You have a good choice of wheels.
MRR FS01 and or FS02
Forgestar Wheels
They are strong and made on order.
Need4speed_motorsports is offline   Reply With Quote
Old 09-19-2016, 08:25 PM   #9
Jayjellyfish212
Drives: 2014 1LE
I'd like to see a flow forge 19" option that looks like the z28. I have 20" and have no intention to spend money to keep same size. I'm not sure how or why everyone is so drawn to 20". It's a waste of added weight and rotation mass. The 19" is the better choice for looks and performance. I'd like to replace my zL1 20" wheels that came on my 1LE but the only wheel I see I like is the OEM z28 rims. Looks like I will be going that route. Seems you can buy some large getto blaster 21-28" rims easier than 19".
Old 09-20-2016, 01:32 PM   #10
Jpsella
Jpsella's Avatar
Drives: 2013 2SS
I'm looking at OZ in 19x10 for a square set up. With winter coming I have a few months to decide. I completely agree on the rotating mass.
Jpsella is offline   Reply With Quote
Old 09-21-2016, 02:42 PM   #11
A good option is the MRR FS01 wheels I have done it before and they work great in 19" fitment.
Used the 285/35/19 Potenza RE-71R tires as well.
Old 09-21-2016, 04:52 PM   #12
Retro69
Retro69's Avatar
Any chance of getting 305's on there?
Old 09-21-2016, 05:58 PM   #13
DarrinSmartL99
Drives: 2010 Camaro SS/2SS
I run a forgestar 19" set-up. 9.5" on front and 11" on rear. Front is 255/45 and rear is 305/35. Tires are about .5" shorter than stock. Really needs atleast drop springs for wheel gap. I have phaestek springs.
DarrinSmartL99 is offline   Reply With Quote
Old 09-21-2016, 08:02 PM   #14
100% it can be done
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
