04-27-2021, 11:44 AM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Flex Wax , application method #2 (drying aid)
Washed the car finally after getting it snowed on & driving through salty slush. During the initial rinse, the water beaded on the top surfaces and sheeted on the lower verticals. Once washed and during the rinse, it went back to beading everywhere.
I usually use the Wet Wax as a drying aid, but this time I decided to use the Flex Wax (the #2 method recommended by TW for application). It did a really good job and the paint felt VERY slick under the drying towel (something I never really felt with the Wet Wax). I did get a FEW smears on the side panels, but I think that it was because the water had almost all run off and the panels were practically dry - I probably should have re-wet them. The finish turned out great, no spots or anything ... except for the few minor smears on some of the sides. I have used the Wet Wax on a dry surface before (applying and removing it the same way I did the Ceramic Spray, or Graphene Spray) and it worked well enough, so I think I'm going to start using the Wet Wax as protection for my rims and door jambs. I still have over 1-1/2 bottles of it left, so it should last a while just using it like that. So far, I have zero complaints about the Flex Wax - application, removal and short-term durability are all good, even with Ohio's *All-Four-Seasons-in-One-Day-Weather.*
Don M
Supercharged LGX + 6 speed manual = FUN!! |
