#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 06-10-2023, 02:26 PM   #1
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Noise from 2023 2SS
2023 2SS, 485 miles, oil level is good.
After it's warmed up, when I start from a stop, there's a ticking sound starting at 20mph & stopping once I get to about 40mph. It doesn't do it when idling at a stop or while idling in park.
Anyone experience this or something similiar?
classicrockr is offline   Reply With Quote
Old 06-10-2023, 03:10 PM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Sound is related to vehicle speed rather than engine RPM? Does the sound change with direction (left turn, right turn, straight)? Maybe a loose lug nut? I would verify that the lug nuts are properly torqued.
Mark114 is online now   Reply With Quote
Old 07-14-2023, 09:45 PM   #3
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Can you tell where it's coming from with windows up vs windows down? Check tire tread for objects?
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Build Log: https://www.camaro6.com/forums/showt...6#post11353116
keep_hope_alive is offline   Reply With Quote
Old 07-15-2023, 11:07 AM   #4
Odabo
Odabo's Avatar
Drives: Chevrolet Blazer
I second that! I recall there was a thread on this topic. Don't delay, check your lug nut torque.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
Odabo is offline   Reply With Quote
Old 07-17-2023, 12:25 PM   #5
Camaro Fanatic
Drives: '23 1SS 1LE
Maybe injector tick too if it's not a super loud noise?
I notice it on mine during lower speed driving (<45MPH). Usually hear it more in the first 5-10 minutes but might just be because my ears haven't tuned it out.
Camaro Fanatic is offline   Reply With Quote
Old 07-17-2023, 01:28 PM   #6
Chris357
Chris357's Avatar
Drives: 2018 ZL1 Garnet Red A10
Had a friend that bought a new mustang several years ago. Complained about a speed dependent tick from under the car.
I said what if its a sticker on the driveshaft or some other rotating part that is coming off and slapping against the body?
Eventually took it into the dealer and guess what? It was a sticker coming off the driveshaft.
not saying that's your issue, but I woudl do a check under the car for stickers or labels on driveshaft or halfshalft/alxes or any other part that rotates with vehicle speed.
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23)
2018 ZL1 Garnet Red A10 (BOUGHT 2/23)
Chris357 is offline   Reply With Quote
