08-18-2021, 10:51 AM | #1 |
Drives: 1970 RS Z28, 1973 Z28, 2014 1LE Join Date: Aug 2011
2014-IKON ZL1 Side Skirt install Help-Please
I recently purchased these and noticed the difficulty in installing them as there isn't molded sections to attach the retaining clips etc. Has anyone purchased and installed these? I am almost to the point of sending them back and buying factory side skirts on ebay that are easy plug and play vs. trying to retro fit these. Anyone have instruction on how to install these? Thank you for the help in advance.
https://ikonmotorsports.com/collecti...-rocker-panels Last edited by ddc456; 08-18-2021 at 11:03 AM. |
08-25-2021, 10:13 AM | #2 |
bump. any help out there?
08-26-2021, 03:06 PM | #3 |
You might want to ask in the "cosmetics" section. This is a body modification that should go there, more visibility.. Good luck..
08-27-2021, 12:44 AM | #4 |
Drives: 2013 L99 Join Date: Jan 2019
Just get the OEM ZL1 rockers. The OEM ones come with new clips, you have to paint them to make them look right. Once painted you just pop the old rocker panels off and put new ones on.
08-27-2021, 10:45 AM | #5 |
I think that is what i am going to do. These are just to complicated, they are basically bare on the back of them....and no hardware.
08-27-2021, 01:04 PM | #6 |
Instagram: Sangstah
These ones you use 3m exterior grade double stick tape and self tapping metal screws into your oem rocker panel underneath.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
Thread Tools | |
